Thread: 3rd Injector Fault Code on 150bhp CDTi
    Regular Member nd11uk's Avatar
    Essex/Suffolk/London
    Default 3rd Injector Fault Code on 150bhp CDTi
    Hope someone can help with this one.
    My Veccy has shown a 3rd Injector fault code on both the readers of the AA and local garage it was recovered to, the 3rd injector was swapped with 4th and system reset but the same fault code has popped up on the reader??
    looking through some other posts I'm confusing myself as to where to start is it electrical?, is the injector programmed so it didn't matter swapping? I have the yellow clips on the wiring if that makes any odds.
    Help
    Administrator plasma's Avatar
    On the Forum
    405 Post(s)
    Engine : 150
    Mileage : 74000
    have a search for '3rd injector wiring mod' . That will apply if the code states that 'injector 3 open circuit' The new wiring for injector 3 should have a blue plug
    Regular Member Grimo72's Avatar
    Apr 2008
    Lincs
    as above you need the new 'blue plug wiring'
    Thanks for the speedy response Guys, I'll pop up to the Dealer and pick up the mod kit.
  1. No1 Injector fault on 150 CDTI
    By bingo999 in forum Engine & Drivetrain
    Last Post: 3rd September 2011, 20:22
  2. 1.9 CDTI fault code P2279-11
    By mozzer99 in forum Engine & Drivetrain
    Last Post: 14th June 2011, 20:13
  3. Injector Wiring Loom (common fault on 3rd injector)
    Last Post: 8th October 2010, 12:18
  4. fault code on my cdti 150 P2279P
    By peadar in forum Diesel Engine related
    Last Post: 18th April 2010, 02:53
  5. signum 1.9 cdti fault code
    By walt1wallace in forum Electrical & ICE (including SatNav)
    Last Post: 16th July 2009, 14:15
are the injector coded to my diesel vectra
injector fault code vauxhall vectra
