Results 1 to 10 of 16
Thread: Scottish Vec owners : Where do you get your Vec serviced?
    Regular Member RSV_Ecosse's Avatar
    Falkirk, Scotland
    Default Scottish Vec owners : Where do you get your Vec serviced?
    My 2004 3.0 V6 CDTi SRi is almost at service time again. It had a full service in 2006 when I got it but since then I've not had it fully serviced although it has had it's oil and filter changed annualy.
    I'm located in Falkirk and I'm looking for recommendations of where to bung mine in to get it serviced. It's done almost 55k, I'm not sure what will be required at the next service at that mileage, when does the timing belt get changed for instance?.
    I'm not taking it to any of my local VX dealerships for the job, it would cost me a fortune and having used both of them before for other things, I'm not that impressed with them anyway.
    So can some kind Scottish fella recommend me a good independant place that knows Vec's inside out for me to get mine serviced at?. I don't mind travelling ( within reason ) a few miles to somewhere that is a trusted place to go.
    Forum Moderator John LE's Avatar
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Why not try here bud http://www.goodgaragescheme.co.uk/
    asdasd
    lol none of the actual decent garages id go for to get any of my cars serviced/fixed isnt listed on that site.
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Its a fairly new service mate, probably take a while to get them all on there
    Quote Originally Posted by RSV_Ecosse View Post
    Good to see a local fellow 3.0 V6 CDTI SRI owner (Cumbernauld isn't that far!)
    I get mine serviced at Arnold Clark Glasgow South, but I've been using them for 10 years now
    Typical service cost is £150 plus VAT and that is using 10w40 oil
    Since your car is out of warranty that oil is sufficient
    I book the car online usually five business days in advance, with a note that I need the car back by 13:00
    I get the car there for 08:30, so that work can be commenced AM
    The reasons I put completion for 13:00 is that they go for an hours lunch
    I then go to the Cineworld in Glasgow, by the time I get back the service is completed
    Sometimes there is warranty repair work, but the problem with this car is the lack of available parts
    It usually takes between 3 and 10 business days for them to come in
    The car is then booked in for the next available day I have and I wait while it is completed, this is one thing where they are really good
    Check if your car is on ECO Flex, if you've never done this before take the key out of the ignition and press the odometer reset
    It will now display the miles left to next service
    If nothing appears, then refer to service book
    The interval on ECO Flex is 2 years / 30K miles, and on standard is 2 years / 20K miles
    This should be your cars third service, based on 5 years old and 55K miles
    How long since the last service?
    edit : I've just seen that the last service was 2006, but oil and filter changes every year
    Full service is every 2 years, with mileage limits as above
    Personally, I would ask for a quote inclusive of oil, oil filter, air filter, pollen filter, and fuel filter
    The front brakes last about 30K miles, the rears about 20K miles
    The discs can last to 3 sets of pads, but its recommended to replace at every second set
    The brake fluid should be changed as well, due every 2 years
    I know you are wary of dealerships, but I've not found an independent I can trust (yet)
    I get quoted a price but it invariably changes
    I use dealerships and the price pretty much never changes so I know exactly what the bill will be before work starts
    The timing belt (cambelt) is 10 years / 100K miles
    However the v-belt comes first at 10 years / 80K miles
    Personally, I would do both at the same time
    Equally, make sure you get the cambelt kit as the two rollers need to be replaced
    The disadvantage on the cambelt is the labour, at 6 hours, which makes this job expensive so ask for the labour rate
    The Arnold Clark I use are getting quite used to my car now, its the only V6 CDTI they ever see, due to the low volume of thie car type
    They managed to complete the cambelt change on mine a few weeks ago in 5 hours
    I do 40K miles a year, so its in for a service every 9 months (20K miles, that's as far sa the service indicator will go)
    The service itself takes between 1 and 2 hours
    The engine takes 8 litres of oil, that alone costs about £50
    My car is still under warranty, and part of that warranty includes the servicing and brakes
    I therefore haven't paid for any of my servicing or repairs yet (see below)
    However, I always ask how much it would have been so that I know what it will cost in future
    The only repairs I paid for myself recently were :
    a new headlight switch, as the internal bulbs had failed (cost £100)
    a replacement key, as the buttons had worn, so I dropped it into a cup of water, but the warranty claim was still refused as the key element still worked (cost £105)
    Falkirk, Scotland
    Wow!!!. That's some excellent info there, many thanks!!.
    I got the pads replaced all round last year, it also got a new set of front discs at that time.
    Glad to hear the belt change intervals are a fair bit off for me so far though!!.
    I have no idea if I'm on ECOFLEX or not, will check tomorrow.
    It makes little difference. as the car is out of warranty
    Equally, its been at least 2 years since the last service so its either ECO service, disabled, or is being reset at the oil and filter changes!
    Strange to get a set of front pads and discs at frst replacement
    My front brake pads went at 30297, 56436, and 74488 the final one getting discs
    As above, I normally replace discs at the second set of pads, but I was advised at 56436 the discs were in good condition and would easily last to the third set
    However, at the third set they agreed they might not last to the end of that set and replacement discs were authorised
    Sadly the same can't be said of the rears!
    At 47535 the rear pads AND discs went!
    67459 the rear pads went!
    I suspect the rear pads are now overdue...
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 110000
    The "bulb" (SMD) only costs pennies and can be swapped in 10 minutes.
    I am the kind of person that can't be bothered replacing such items myself
    Removing the trim, opening it up, replacing all the failed bulbs, reassembling, replacing trim
    I now have the old headlight switch as a spare
    I haven't had the time yet to strip it down and replace the bulbs
    If it goes again then I can reuse
    If not, then it can be sold
    Regular Member pogo's Avatar
    Feb 2006
    Vehicle : Insignia
    Trim : Sri
    Engine : 2.0 turbo petrol
    Year : 2010
    try autovaux mate they are independant vauxhall specialists located at carron place kelvin industrial estate east kilbride i use them all the time and cant recommend them highly enough,try and avoid arnold clark as they are worse than useless imo,although im sure others will disagree
  1. scottish owners 2011
    By DAVIDD88 in forum West Scotland (RO - Mr Gee, ARO - RBH)
    Last Post: 25th February 2016, 23:39
  2. never been serviced????
    By rob warrington in forum The 'Off Topic' room
    Last Post: 3rd June 2010, 14:00
  3. Just serviced.
    By Maverick in forum Vectra C / Signum Car Chat
    Last Post: 12th August 2009, 16:52
  4. !!!Attention all diesel owners!!! (Petrol owners may want a look too!)
    By John LE in forum Vectra C / Signum Car Chat
    Last Post: 18th April 2009, 20:56
  5. Serviced by vx at 58,861
    By ProfessorFalken in forum Vectra C / Signum Car Chat
    Last Post: 8th January 2008, 13:40
