Results 1 to 10 of 15
Thread: Alarm - can it be disabled
    Nottingham
    Default Alarm - can it be disabled
    2.8 elite - alarm keeps going off. Any easy way to disable
    have you tried pushing the button next to the radio to disarm the internal sensors in case its them?
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    I bet you have an estate? If so the glass breakage wire that runs around the boot glass will have been damaged mate, its quite common on the estate.
    11 Post(s)
    Quote Originally Posted by stripey View Post
    If there was, it would make a thieves job that much easier.
    If you don't want to set the alarm until you've got someone to take a look at it, lock the doors manually via reaching in though the passenger door or rear door and pressing the lock button on the door panel. I should point out that the deadlocks won't be set though.
    I take it the LED on the dash is flashing up there is a fault? If so, then the easiest solution would be to get the fault code read out.
    Regular Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    I am glad nobody has said anything on the forum...
    Who knows what scrotes are reading this looking for tips...and a fast T.W.O.K. or fast buck!!
    Nottingham
    Quote Originally Posted by Robsey View Post
    That's a fair point but when you're sat there at home with the alarm going off every five minutes you've got to try something
    Think it is the estate issue - how easy is that to fix?
    Regular Member monty2000's Avatar
    Sep 2009
    swansea
    Vehicle : Vectra C Pre Face, Colour Coded, CR Tech Box, Pipercross Panel filte, Blanked EGR :-)
    Trim : Club
    Engine : 1.9cdti 16v
    i was going through my manual this morning & noticed theres a fuse in the boot for the alarm. i maybe wrong but it might shut up the alarm if you take it out
    Nottingham
    Thanks Monty - I'll dig the book out when I get home. Currenlty resorting to using the key
    Ashington, Northumberland
    You can Tech 2 it out of commission all together if you want
    Regular Member si_hoss's Avatar
    Apr 2009
    Stevenage, Herts
    I have the same issue (although not seen it for a while now) and I simply unplugged the siren, so all the lights flash but no noise.
    I believe newer Vectras revert to using the horn if the siren is unplugged, but mine doesn't.
    Since I've now told you this, I DON'T drive a blue Vectra in Stevenage......honest
  1. Remap - EGR Disabled
    By Fig-sri in forum Diesel Engine related
    Last Post: 3rd July 2010, 21:50
  2. Disabled people's scooters.
    By Gr4eme in forum The 'Off Topic' room
    Last Post: 11th October 2009, 11:00
  3. Disabled drivers ???
    By Batesie in forum Vectra C / Signum Car Chat
    Last Post: 25th May 2007, 09:30
