Thread: Draining Oil on a 1.9cdti URGENT!
    Regular Member CDTi-SRi-Matt's Avatar
    Nottingham
    Default Draining Oil on a 1.9cdti URGENT!
    URGENT
    found thread on how2 but still cant locate the plug to drain oil, where abouts is it situated? left or right of the car etc? i havent a clue and this is really urgent!
    Ta Matt
    Right hand side of the engine looking forward, it's a torx bolt at the bottom of the sump but screwed in on the back horizontally...
    preston
    I have a cdti and it wasn't a torx bolt on mine, just a normal hex bolt, 13mm if I'm correct. You'll need a new one probably as they are tight and you end up chiselling them off.
    I might be lying then, but I'm sure mine was... Might be my old Vec B I'm thinking of, but I remember once getting it up on the ramp to change it, then findign out it was a Torx. Back to Halfords I went...
    So long ago in fact you might be right...
    preston
    Car needs to be jacked up high or preferably on ramps to allow the undershield door to hinge down far enough so you can get a bowl underneath to catch the oil
    Nottingham
    Its ok couldnt find it and its in at the garage first thing.
    Sods law im going on holiday 2moz and doing a 300 mile journey so checked oil level, topped up but just a LITTLE too much! in fact about 3 times too much! dont ask why, think i just got happy.
    But luckily we know the person at the garage so he got me in first thing.
    Thanks for your help though
    Matt
    Regular Member WHOOSH05's Avatar
    On the back wheel
    13mm hex and they normally round off.
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    allways use a single hexagon socket never fails
    On the back wheel
    Quote Originally Posted by jonnybravo View Post
    always do and its happend twice on two different cars
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    had mine over 5yrs and is as good as new!! ,
  1. Draining Coolant
    By Lean6 in forum Vectra C / Signum Car Chat
    Last Post: 7th April 2012, 21:25
  2. Battery draining
    By Rob12 in forum Electrical & ICE (including SatNav)
    Last Post: 8th October 2011, 23:30
  3. Battery keeps draining
    By ScottR in forum Electrical & ICE (including SatNav)
    Last Post: 13th May 2010, 15:08
  4. Urgent advice - Signum 1.9cdti clutch smell
    By pscocoa in forum Engine & Drivetrain
    Last Post: 2nd August 2008, 11:41
  5. draining the water
    By chrisgettings in forum Vectra C / Signum Car Chat
    Last Post: 2nd February 2008, 23:45
