Thread: Question for any heating engineers out there (or any other knowledgeable veccy's)
    Regular Member Doug-SRidirect's Avatar
    Hemel Hempstead
    Default Question for any heating engineers out there (or any other knowledgeable veccy's)
    Quick non-Vec related query:
    Iíve hidden our wall-mounted Potterton boiler inside a 920 high x 500 wide wall unit, as part of the utility room refurbishments. The top, Iíve cut away locally to clear the boiler pipework.
    Two questions:
    1) I need to cut a vent hole in the bottom of the cabinet. What size vent will I need?
    2) Where can I get a job like Prescottís? Full pay (free houses, cars, and secretaries!!!), all for doing no work at all!
    Iím calling at B&Q on my way home tonight to buy a louvred (fixed) plastic vent grille, so need to know what size to buy.
    Any plumbers / heating engineers out there???
    Doug
    May 2006
    Nottingham
    Quote Originally Posted by Doug-SRidirect
    Two questions:
    Doug
    Do you have the manual for the boiler, is should tell you in there.
    A
    Hemel Hempstead
    No manual....boiler was in the house when wew moved in.
    North east HQ
    hi doug, depending on the type of boiler and size but generally:-
    wall mounted, conventional system (ie. tanks, cylinder) then compartment ventilation is 200cm2 both high and low level (suggest leave the top of the cupboard open) but also you need vents in the kitchen to outside to provide adequate air to the room
    if it is a combi/comdensing boiler then generally after looking through pottertons literature, there is no need for ventilation.
    North east HQ
    you can download user instructions from here
    Hemel Hempstead
    Thanks for that Wayne, that's exactly what I was after. It's actually a conventional boiler and there's at least 200 x 100 cut away to the top and I'll make the bottom cabinet opening similar sized tonight - and this doesn't count the gaps around the door.
    Doug
  1. FAO Rob Warrington or any heating engineers
    By dannyjpuk in forum The 'Off Topic' room
    Last Post: 12th February 2012, 21:34
  2. confused.com -------- heating and fire question
    By dannyjpuk in forum General Chat
    Last Post: 17th December 2011, 23:50
  3. any heating engineers in tonight ??
    By bembo449 in forum The 'Off Topic' room
    Last Post: 2nd July 2011, 20:38
  4. Heating temperature control not working - Full heating permanently
    By jratcliffe3 in forum Electrical & ICE (including SatNav)
    Last Post: 31st January 2010, 23:46
  5. Rear heating window question..
    By Jim Bob in forum Vectra C / Signum Car Chat
    Last Post: 16th October 2008, 16:52
