Thread: yellow oil light on a 2.0 dti
    worcester
    Default yellow oil light on a 2.0 dti
    My oil light keeps coming on when ever the car has been on long run and is at idle speed. A quick rev of the engine and the light disappears. Checked oil level and all is okay.
    If sensor playing up where is it on signum 2.0dti 2004 model and can it be replaced by a DIY person?
    Thanks in advance.
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    yes bud it.s straight forward jack up car and support (don't just use a jack)remove engine lower cover,it's in the side of engine block just above drive shaft.unplug wiring harness and remove switch.tighten switch to 30 Nm
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    I think the OP is talking about the oil level sensor and not the pressure sensor. The level sensor is on the front of the oil sump
    Jul 2009
    sussex
    do all vectra c's have a level sensor?
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    All the ones witch check contol. If yours is an elite as per your profile yours will have it
  1. Yellow oil can light help
    By andyrad29 in forum Vectra C / Signum Car Chat
    Last Post: 29th August 2012, 23:54
  2. Orange/Yellow Oil Warning Light
    By countduckula55 in forum Vectra C / Signum Troubleshooting
    Last Post: 10th July 2011, 17:44
  3. yellow Oil can light on dash
    By flyinggazza150 in forum Engine & Drivetrain
    Last Post: 16th February 2011, 23:21
  4. yellow car/spanner light
    By jeff55550 in forum Vectra C / Signum Car Chat
    Last Post: 18th March 2010, 01:25
  5. Yellow Light
    By Mark2.2 in forum Electrical & ICE (including SatNav)
    Last Post: 8th October 2008, 15:42
