Thread: vectra 150 55 Plate Failed MOT
    Redcar
    Default vectra 150 55 Plate Failed MOT
    Hi I have just came back from dealers with a Failed Mot Vectra. They reckon its got 3 cyclinders working out of 4 and that the front of exhaust is cracked. They originally thought it was egr valve, but they took that out and cleaned and it didnt resolve problem. It seems to be using alot of oil. Iam not sure what to do but think small garage is better bet. Do i go into diffrent garage with my failed mot results or let them pick up on them there selves. I dont want to be hurt in the pocket :-D
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Go to a small garage with your fail sheet and let them sort it all. Then take it back to the original test station and get a retest (sometimes free or for a partial fee)
    Full Member Big Sig's Avatar
    Havee you seen the posts on the 3rd injector mod? It may need doing on yours.
    spoons
    Guest
    earlier this year I took my Astra in for its MOT which failed on the exhaust backbox.
    Garage quoted me £200 for a stainless steel replacement. Which I laughed as the car only cost me £400
    They then requoted £100 for a steel replacement... so I went elsewhere..
    Shortly afterwards and a couple of phone calls...
    £34.60 cash for replacement including fitting and VAT !!
    Took it back and they charged me £10 for a retest which involved just to look at the exhaust, tick a box and print out my MOT Certificate... ripoff
    Redcar
    It sounds like a bag of poo after leaving garage and its in safe mode. How much does it cost to replace a broken cylinder??
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    A cylinder is where the piston moves up and down mate, could be a number of reasons for why its not firing
    As mentioned could be injector wiring
    Faulty injector
    Swirl flap problems etc.
    If its the cylinder block/pistons you'll be talking mega bucks as in new engine but its very unlikely its that. Get the car onto diagnosis to see what fault codes are being given
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    if they have told you you have a broken cylinder how long did it take you to stop laughing?????????????????????/, GO ELSEWHERE FOR A 2ND OPPINION. look in the how 2s for 3rd injector wiring, try putting a screwdriver to each injector to listen for irregular noises, take off the egr again also in the how 2s give it a strip + good clean (don't forget to clean the hole where it fits to the manifold) clean the boost sensor (how 2s). if all fails ask friends or on site for a recommended garage near you. good luck
    Regular Member Driver0069's Avatar
    Oct 2009
    South Yorkshire
    I once took a car to dealers for a mot and found a long list of things my mate told me to go to a small garage and passed it i still have the car and it passed 3 times in a row just watch out they all are scams
    Redcar
    Its a shame i cant turn get home mode off as its doing my head in!!
    Disconnect the battery for 30 mins, that should do it unless its a present fault. make sure you have all the sodes you may need if you do
  1. MOT failed on vectra 1.9 need help
    By faizyan6000 in forum Suspension, Wheels & Brakes
    Last Post: 17th August 2011, 13:55
  2. Vectra failed mot
    By davidlewis24 in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2011, 17:26
  3. Failed MOT! Number plate spacing +
    By caravaner-tony in forum Vectra C / Signum Car Chat
    Last Post: 21st May 2010, 18:00
  4. Vectra 2005 2.2 SRI Direct Interior Fan/Demistor failed
    By sanderstrog in forum Vectra C / Signum Car Chat
    Last Post: 5th January 2010, 20:35
  5. Vectra cat converter failed
    By starcopal in forum Engine & Drivetrain
    Last Post: 8th March 2008, 19:09
