Thread: Replacing my GID with a CID
    Regular Member jacko39's Avatar
    Sep 2009
    Derbyshire
    Default Replacing my GID with a CID
    Hi
    I am currently looking into changing my head unit to a double din touch screen model with sat nav. At the same time I was thinking that I would like to replace the GID with a CID, and display the SatNav on that also. I have seen a few threads regarding the CID taking an AV input, and thought that this might be the way to go.
    I have found a CID on Ebay, but to be honest Im unsure whether it will work in my car (2003 Vectra SRI). I am new to this so i'm not 100% sure what is meant by the CID being unpaired/unmarried/tech 2'd etc. Would somebody please be able to explain to me (in simpleton terms!!)?
    The CID is here : http://cgi.ebay.co.uk/Vauxhall-Vectr...d=p3286.c0.m14
    Any help/guidance would be appreciated.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    yep that will fit your car..
    Weather if it will take a external input i dont know. but wouldt be much use if no NCDC to control thescreen, as the radio controls all funktions of the screen.
    WGAF#5
    Quote Originally Posted by jacko39 View Post
    Hi
    basically the head unit and display are "married" to each other when fitted
    unless they get a "divorce" (Tech 2 to unpair them from each other) they wont work independantly so might not be the bargain you were thinking of unless this has been accomplished by a vx garage or someone with the necessary vx decoding hard/software
    Regular Member Driver0069's Avatar
    Oct 2009
    South Yorkshire
    Exclamation sat nav
    I was looking at the same item but then made some phone calls and found out they have codes in and its not that simple so now i have changed my mind i will stick with my tom tom let me know how you get on mate and i will try and find you some moe info
    Engine : 2.2 Direct
    The add dosnt say if decoded or not but it can be decoded.. or if cid and ncdc is from same car still no problem.
    Regular Member Matt&Jemz's Avatar
    CORNWALL
    let us know if you will be doing this as you may need different vents depending which model you have we have some spare vents bought to retro fit the sat nav screen as they are bigger than the normal screens its brand new by the way
    Oct 2009
    South Yorkshire
    rolleyes sat nav
    I am sure there will be someone who has fitted one before
  1. Replacing cim ?
    By Mr Owens in forum Electrical & ICE (including SatNav)
    Last Post: 28th August 2012, 10:10
  2. replacing the REC
    By les287 in forum Electrical & ICE (including SatNav)
    Last Post: 18th May 2011, 04:14
  3. egr needs replacing?
    By family guy in forum Engine & Drivetrain
    Last Post: 20th April 2011, 10:41
  4. Replacing the CIM
    By Martyn21 in forum Electrical & ICE (including SatNav)
    Last Post: 30th December 2010, 18:22
  5. Replacing DMF
    By RikD in forum Vectra C / Signum Car Chat
    Last Post: 27th January 2010, 21:55
