Results 1 to 3 of 3
Thread: Wont start
    Central Scotland
    Default Wont start
    03 1.8 petrol
    For some time I've had these two error codes-
    Fuel trim malfunction
    MAP or MAF malfunction
    Fuel consumption into the teens..over fueling and failed emissions test. One night I got in and started as normal, it cut out within ten seconds and wont start, not even a hint of it.
    At first I thought fuel pump, however, if I disconnect the battery for over an hour and things reset, the car will start instantly and run for 20 minutes or so, then same thing again.
    MOT said the lambda was outwith its limits and advised to change but my scanner says lambda is ok when the engine is running????
    My guess is a sensor or something simple, trying to save a bit of money here by not replacing something that's not needed. It's already cost a few hundred when the RAC wrongly diagnosed the car
    Jul 2009
    sussex
    try getting a cheap map + maf from a scrappy.
    shame as i just sold 2 really cheap on ebay.
    They could definitely be the cause of your woes.
    try checking for air leaks around the inlet mani and the throttle body and this will cause a lean mix.
    also, it wont be your O2 sensor as that must be working to know that there is a lean/rich fault in the fuel.
    Central Scotland
    Thanks John.
    Would a faulty MAP of MAF stop the engine running?
  1. wont start
    By wsophiecat in forum Engine & Drivetrain
    Last Post: 17th December 2011, 17:17
  2. 2.2 cut out now wont start
    By spink1972 in forum Engine & Drivetrain
    Last Post: 22nd April 2011, 08:32
  3. Car wont start - please help
    By zafira in forum Diesel Engine related
    Last Post: 6th November 2010, 14:25
  4. Will not start then it will then it wont????
    By djconfused in forum Engine & Drivetrain
    Last Post: 29th July 2010, 21:37
  5. car wont start!
    By briancdti in forum Vectra C / Signum Car Chat
    Last Post: 11th November 2008, 20:11
