Thread: Traction Control light staying on !!
    Market Harborough
    Default Traction Control light staying on !!
    Hi there could anyone shed some light on a promblem i am experencing on my 04 reg Vectra 1.9CDTi 16v
    Well when I start the car all seems ok till I move off and the traction Controll light iluminates and stay lit !? Not only that bt whilst driving stedy the ABS light filickes too and occasionally get a picture of a steeringwheel with an exclamation mark iluminate (well flicker) in the display in the rev counter
    Can anyone help med shed some light on this or know what maybe up with it ?
    Personally i think it could be a wheel speed sensor gone down, I know for a fact I need to change the driverside front hub bearing as it sounds rough on rotation and i am in formed from a vauxhal specialist that this is a comon part to fail on the Vectra C's and on the wheel bearing is your ringed gear for the weheel speed sensor !! So I think il change that next week on my week off to eliminate that before I go paying out at vauxhall to try to diagnose it ?!
    but i'd love to hear anyones sujestions or ideas all could help and ill update everyone how I get on when iv done it next week
    Cheers for now
    Chris
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Deffo sounds like an abs sensor/connection mate
    Admin plasma's Avatar
    On the Forum
    333 Post(s)
    Engine : 150
    Mileage : 74000
    Find a friendly garage to do a code read, will put you on the right path of what to fix
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Quote Originally Posted by plasma View Post
    Rather pointless until either the EMS or engine warning light come on
    As above, sounds like the ABS sensor is at fault
    Does this happen on any specific road conditions, such as wet or dry, when turning left?
    Equally, when the TC comes on, try the indicators
    If the indicators stay on and won't cancel, then it's the CIM that has failed
    Wellington
    How many speed sensors are installed on the Vectra C
    I had one replaced in May now been told, after the car shut down same symptons, abs light on traction light on and steering wheel light with exclamation then car stops, the Tech 2 is picking up a speed sensor fault! and also immobeliser fault!!!
    Any ideas?
    Mar 2007
    Tamworth
    Quote Originally Posted by JimNZ View Post
    Any ideas?
    4 - one on each wheel - ABS needs to detect each wheel's speed.
    May 2008
    Helsinki
    Get fault codes first. I had similiar problem with my 3.2 and It was the CIM module steering wheel angle sensor that needed to be recalibrated. I had messed It when changing the steerinwheel. Total costs were 30€ to get codes & calibrate. 15 min Job with tech 2.
    Wellington
    thanks guys
  1. HHmmmm Traction control light staying on
    By Mark-R in forum Suspension, Wheels & Brakes
    Last Post: 19th October 2012, 00:27
  2. PLEEEEASE HELP - traction control light/power steering light on!!!
    By holdenvectra in forum Electrical & ICE (including SatNav)
    Last Post: 28th June 2010, 23:39
  3. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
  4. Help abs & traction light staying on.
    By Teza in forum Suspension, Wheels & Brakes
    Last Post: 14th December 2008, 17:09
  5. traction control light
    By chosen1 in forum Vectra C / Signum Car Chat
    Last Post: 2nd June 2008, 09:02
vectra vxr traction control light on
