Thread: Footwell Not Drying
    Aug 2009
    Durham
    Default Footwell Not Drying
    Hello,
    Had the old problem of the scuttle filter being blocked about 3 or 4 weeks ago and had a valeter dry out the car as best as he could (2 vac's full) and it appeared to dry but one patch in the front footwell just stays damp and had a quite a lot of rain this week and filter still clear.
    Anyone think it's still just drying out or another problem. Door seals seem to be OK and rear footwell appears OK.
    lanark
    Vehicle : Insignia Elite Nav
    Year : 2012
    Mileage : 9k
    have you checked the drain holes at the pollen filter
    Regular Member paul wingnut's Avatar
    durham
    Vehicle : vectra sri 150
    Engine : 1900 cdti 150
    i had same trouble with mine i had to pull carpet back in footwell cut out sponge and dry floor when the sponge dried out put it all back its ok now if you dont get it dried out it starts to smell
    Aug 2009
    Durham
    Thanks for advice. Do I need to take seat out, not the most DIY or car friendly person. Is it easy enough to do. Pollen filter changed by garage after it got wet again.
    durham
    sorry for being late to reply can do it without taking seat out but easier with glove box out
    WGAF#5
    do you have access to a dehumidifier ?
    if so put it in the car wind the wndows up carefully close the the door as to not damage the mains lead and leave it plugged in
    should remove the moisture content - hopefully otherwise you will need to remove the seats the carpet and the underlay which is where i suspect the moisture is trapped - then dry them each indicidually - water test the car before refitting the carpets and then you shoudl be ok
    Full Member Big Sig's Avatar
    If you have rear vents then put the air distrubtion to vent only and close the front ones. The pipes for the rear vents go under the carpet in the front footwells.
    Nov 2010
    North Yorkshire
    Vehicle : Signum Elite 1.9 CDTI
    Engine : 1.9 (150)
    Mileage : 113.000
    Quote Originally Posted by KN1 View Post
    Hello,
    I've just noticed on my Signum that there is a damp patch on the driver's side carpet right against the sill and about halfway down. It's not soaking, but it's better sorted than left.
    I think a check of the scuttle drain is the first step, but where is it located?
    Nov 2010
    North Yorkshire
    Engine : 1.9 (150)
    Mileage : 113.000
    ............ any advice on the above problem would be appreciated.
    Regular Member Jezzy's Avatar
    S.E
    Have a look at the picture below; the red arrow points to the drain hole, it's located in front of the pollen filter (the white corrugated thing you can see behind the arrow). The drain hole is at the bottom of that compartment. Use a long screwdriver or a stick push out any debris that's in the hole.
  1. Drying a black car
    By damers2000 in forum Detailing and Car Care Discussion
    Last Post: 15th August 2011, 19:05
  2. Drying Towel???
    By Mark The Cabby in forum Detailing and Car Care Discussion
    Last Post: 11th March 2011, 10:20
  3. Drying towels.
    By Das in forum Detailing and Car Care Discussion
    Last Post: 19th November 2010, 23:12
  4. What a lovely drying day it is!
    By John C S in forum Comedy & Humour
    Last Post: 31st May 2009, 15:30
  5. drying
    By howd3y in forum Detailing and Car Care Discussion
    Last Post: 17th April 2009, 19:31
Scuttle drains on insignia
vectra c pollen filter location
