Thread: rear washer sprayer
    Sep 2009
    Glasgow
    confused rear washer sprayer
    Hi all booked my car into the local stealers to get my rear washer looked at got a phone call yesterday, garage had a power cut and could't get the car up on the ramp, i've collected it and am giving it one more go to get it working myself , took cap of washer bottle removed rear spray and blasted compressed air through it bubbles galore appeared from the washer bottle, i let this run for about 5-6 minutes, i've also let the washer spray sit in boiling water to clean it. Does anyone think this i pump related as my front washer have great pressure just the rear i'm having problems with.
    Sep 2009
    Glasgow
    update have water going through the sprayer but there is no pressure to it at all it is spraying but the slightest breeze and when traveling about 30 mph it the spray gets blown behind the car, my old car astra 1.7 cdti that the wife drives has a powerful rear washer that equals the front, what is the problem it's making me mad but my newer car the vectra has powerfull front washers and a low powered spray at the rear, is this just the way they are.
    WGAF#5
    im guessing here based on other marques- i take it that its a single pump with a ballbearing operated valve - i suspect this is sticking and has caused the problem - might need a new washer pump to resolve the matter
    Hth
    regards
    Dez
    Nottinghamshire
    Take the 2 outlet pipes off of the washer pump and get someone to wash the windscreen then the rear window.
    Less water is pumped out of the outlet for the rear window than the outlet for the windscreen but there should still be a good flow of water to make it jet out of the nozzle with some force.
    Are you getting a good blast of water out of all 4 winscreen nozzles, especially the one nearest the offside?
    Sep 2009
    Glasgow
    no issues with front washers pressure all equal throught all 4 nozzles, car still under 30 day warranty so 5 min ago booked it back in to be looked at tues 12 oct. hopefully they wont have another power cut
    lanark
    Vehicle : Insignia Elite Nav
    Year : 2012
    Mileage : 9k
    iv got poor spray to the rear as well it might be the length the water has to travel on a small pump
    Nottinghamshire
    Quote Originally Posted by neverlandandy View Post
    I've got loads of pressure on the rear washer - the water hits the glass and bounces off so much that it washes the front of the car behind. I guess that's because the water hits the glass at such as narrow angle.
    Full pressure coming out of all of the front jets would indicate that it's a problem with the pipe or jet for the rear washer rather than the pump, but you never know...
    Sep 2009
    Glasgow
    must be the pipe because jet is clear, cant find any water leaking when i operate rear washer, what i did notice was the pipe was attached to the rear spray but on the bottom of the spray there is a rubber ring does the pipe have to be over this as of now it is underneath it but it still is a very tight fit. dont think this is the problem though, the rubber seal i think is for sealing it to the ariel base.
    Nottinghamshire
    Quote Originally Posted by nokiaman1978 View Post
    Yes the rubber ring is to stop water getting into the aerial base - and then the car roof, so well worth making sure it's located correctly although it won't be causing the lack of water pressure problem.
    Sep 2009
    Glasgow
    update after 2 days in the local stealers, just got a phone call to say car was ready for collection, pump replaced because the other one burnt out and tubes cleared out.
  1. Rear washer jet.
    By burbling1 in forum Bodywork & Interior
    Last Post: 8th November 2012, 22:22
  2. rear washer jet
    By bret.c in forum Electrical & ICE (including SatNav)
    Last Post: 30th October 2010, 15:04
  3. Rear Sprayer not working...
    By David_SRi_2.2DTi in forum Troubleshooting
    Last Post: 6th August 2007, 22:27
  4. Rear Wash Wiper Sprayer
    By David_SRi_2.2DTi in forum Bodywork & Interior
    Last Post: 23rd July 2007, 10:39
  5. Aerial and rear window sprayer
    By Johnytuono in forum Vectra C / Signum Car Chat
    Last Post: 25th November 2006, 05:12
where is the washer bottle for the rear washer on a vauxhall vectra
