Thread: vectra cdti 150 brake issue
    Regular Member robk6112's Avatar
    Halifax
    confused vectra cdti 150 brake issue
    I was driving to work this morning about half way into the journey pressed the brake pedal and nothing- 5hit myself and pressed again the and the brakes worked thankfully. They are now working again but feel spongy. Any ideas? Pads and discs have only done around 10k.....
    Regular Member yorkshireborn's Avatar
    Apr 2006
    Rotherham SouthYorkshire
    Vehicle : saab 95
    Engine : 2.3t
    could be air / water in the system
    Regular Member Readster's Avatar
    Plymouth
    not good matey.
    I would check the brake fluid level first.
    But, you have to go through the system and check every component to find the fault. If the pedal went to the floor and the fluid level is ok I would initially suspect :
    1) Servo leak
    2) Master cylinder fault.
    3 Air in the System.
    Did any warning lights come up on the dash?
    When were the brakes checked last?
    when was the Brake fluid last changed? Its supposed to be every 2 years.
    I wouldn't continue to drive your Vec till its sorted as the boys in blue take a dim view of defective brakes...
    John
    Halifax
    av booked it into the garage for this and some more faults next week- wont drive till it goes in. Am going to check the levels at lunch.
  1. vectra 2005 cdti 120 BIG issue
    By mattybutty in forum Electrical & ICE (including SatNav)
    Last Post: 2nd August 2012, 21:11
  2. Vectra C 1.9 CDTi DPF issue???
    By lysander2k in forum Engine & Drivetrain
    Last Post: 25th July 2012, 21:33
  3. Potential issue with Vectra V6 CDTI SRI 3.0l
    By gdallas in forum Troubleshooting
    Last Post: 20th July 2011, 05:19
  4. 2005 cdti vectra sri 120 bottom end issue
    By matt_harw in forum Engine & Drivetrain
    Last Post: 30th March 2010, 08:48
  5. Vectra 1.9 CDTI SRI Nav Engine Misfire issue
    By Joe1 in forum Engine & Drivetrain
    Last Post: 16th September 2009, 10:14
