Thread: CD70 Upgrade
    Regular Member r.bailey63's Avatar
    Mar 2007
    Stockton on Tees
    Default CD70 Upgrade
    I have been offered a used CD70 & Screen taken from a 2004 car, what would i need or what would be involved in fitting it in replacement to my standard CD player?
    Full Member Robsey's Avatar
    North East Cheshire
    21 Post(s)
    Trim : Energy
    Mileage : 131,000
    There are several threads on this...many of which I have posted on.
    The general gist is as follows: -
    1 Tech 2 your radio and screen out of the car. (need your audio pass code)
    2 Remove the trim strip across the front of the dash (unclips)
    3 Remove the 4 x torx screws to remove air-vent and display panel.
    4 disconnect the grey plug from behind the display..remove display from surround.
    5 Extract the head unit using double din tools...or small alen-keys...
    6 Disconnect the Quadlock main 40 pin connector and the white radio aerial fakra plug
    7 Fit your sat nav aerial either in place of the existing roof aerial, or use after market patch aerial that can be mounted almost anywhere in the car.
    8 Connect GPS aerial Blue fakra Plug, White radio aerial fakra plug and Quadlock multiplug to the CD70 head-unit.
    9 If you have a colour screen, you will also need to fit the 12 pin video lead.
    10 feed the video lead through back of radio cage and into space behind the display
    11 push CD70 back into the facia tilit clicks
    12 connect up 32 pin grey plug (and 12 pin video plug for colour screen) to display
    13 Fit the display back into air vent surround
    14 Fit air vent / display surround back into facia.
    15 Refit trim strip across the dash
    16 Get your dealer to Tech 2 the screen and headunit into your car (need your audio pass code)
    17 enjoy!!
    Time consuming parts are the GPS aerial fitting and the Tech 2 programming.
    The actual removal, and refitting of the radio takes about ten minutes tops.
    Mar 2007
    Stockton on Tees
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    and you need to convert your iso block to fakra first and change the heater dials, and steering wheel controls..
    Mar 2007
    Stockton on Tees
    Quote Originally Posted by kenp View Post
    Whats the difference in the heaters dials?
    Engine : 2.2 Direct
    somthing with the canbus cant remember excatly.. but its because you actually need to revert the radio, screen and heater to a "05 model year" and not only parts of it.
    Mar 2007
    Stockton on Tees
    Dont think im going to bother with a CD70, will stick to my tomtom,
    Is it possible just to upgrade to a colour screen?
    Engine : 2.2 Direct
    nope fraid not.
    Mar 2007
    Stockton on Tees
    Thanks, guess i will just stick with what ive got!
  1. CD70 upgrade
    By barneytravolta in forum Electrical & ICE (including SatNav)
    Last Post: 12th July 2012, 14:14
  2. CD70 upgrade
    By patch22 in forum Electrical & ICE (including SatNav)
    Last Post: 29th December 2011, 02:38
  3. CD70 upgrade
    By TopRod in forum Electrical & ICE (including SatNav)
    Last Post: 22nd October 2010, 21:51
  4. Cd70 Nav Upgrade
    By LOCKSTOCK in forum Electrical & ICE (including SatNav)
    Last Post: 22nd July 2008, 16:25
