Results 1 to 10 of 23
Thread: Cruise control
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    Default Cruise control
    jut got back from a 200 mile trip so i was on the motoway and thought ill put CC on so i pressed the top button and it switched on, all worked , 10 mins later i wanted to over take so i kept my finger on the top button and it kept turning it self off, same when pressing the bottom button, but if i was going 70 and pressed top button to store speed it all worked fine its just when i need to over take , what could be wrong? the stalk?
    Regular Member r.bailey63's Avatar
    Mar 2007
    Stockton on Tees
    Clutch Spring, most likely
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Not sure if the buttons are meant for over taking mate, think your just meant to tap them up/down to adjust speed. I'm probably wrong though
    Oct 2009
    Sandwell
    even when i tap em some times it dont work and turns it off, also if its
    cruising at 70 and my finger is just touching the buttons (not pressing them) it also trips it so it nocks it off
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Possible a dodgy stalk then mate, try following the How2 to remove it and clean all of the connections
    To quote from the handbook:
    Increase
    With cruise control active, hold down button or tap it repeatedly: speed is increased continuously or in steps of 1.2 mph (2 km/h) without using the accelerator pedal.
    Decelerate
    With cruise control active, press button or tap it repeatedly: speed is reduced continuously or in steps of 1.2 mph (2 km/h)
    May 2008
    Derbyshire (south)
    As above really, if you want to increase your speed on the motorway tap the control up or down to decrease.
    The connectors may need cleaning, as already suggested??
    If you wish to over take to pass a vehicle on the motorway, just dab the accelerator to increase, once you have passed, release your foot off,, the original speed of the cc will resume.
    Just a thought, when pressing the upper or lower button, you didn't accidentally press the cancel button behind the other two buttons?
    Edinburgh
    Regular Member old cruiser's Avatar
    slough
    That's what I was thinking, if not, then a dodgy stalk/ connections would be my guess.
    Cheers Pete
  1. Cruise Control
    By tony100la in forum Vectra C / Signum Car Chat
    Last Post: 7th March 2010, 19:43
  2. cruise control
    By stuart bigboy in forum Electrical & ICE (including SatNav)
    Last Post: 26th May 2008, 21:14
  3. Cruise Control
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 12th May 2008, 17:36
  4. manual control or cruise control.
    By johnm in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2008, 14:20
  5. Cruise Control not there?
    By Robsey in forum Electrical & ICE (including SatNav)
    Last Post: 1st February 2007, 18:23
vectra c cruise goes off when using reduce speed button
