Results 1 to 10 of 13
Thread: booked in for brake noise
    Regular Member dezzie's Avatar
    May 2006
    blackpool
    Default booked in for brake noise
    car is booked in for this coming saturday to noisy rear brakes sotred out. the guy at VX said should only take about an hour so i will probably hang around there. have been reading some earlier posts regarding this problem. just one question , is this going to be a recurring problem? job being done FOC only 2 months into networkQ warranty
    Regular Member v6boy's Avatar
    PRESTON
    Trim : GSI
    I took mine in recently for noise from rear brakes, they told me that there was nothing wrong with it , it's just a charcteristic of the car, and get this, they said its because of the big gaps in the alloys, dirt gets onto the discs/pads. I mean big gaps in the alloys on a GSi??
    Regular Member storey_3000's Avatar
    May 2006
    somerset
    I had a back brake noise and they told me i needed new discs, pads and calipers!! Bout £650 quids worth. It turned out to be that some drongo hadn't fitted the pads properly (not clipped em to the pistons). Took my local garage bout 30 seconds to realise the problem. Fixed it free of charge. I later found out that the TIS advises to replace everything if the customer complains of noisy breaks!
    Quote Originally Posted by v6boy
    I've been told it's due to the pads not having asbestos these days. Why the rears only do it, and not the fronts, I don't know.
    May 2006
    blackpool
    am i going to get the problem recurring though??
    Depends,
    if they fit VX pads then possibly..Aftermarket one's don't give so much noise..
    Personally, i've grown so used to it, it doesn't bother me now..
    Nr Cardiff
    Interestingly, I've just had to replace the rear pads on my Signum. They were 90% worn at the service.
    The fronts still have 20k left in them!
    How can it be that the rears wear out in 40k, the fronts in 60k?
    I'd have thought the fronts would be working harder, especially on an auto.
    Regular Member yorkshireborn's Avatar
    Apr 2006
    Rotherham SouthYorkshire
    Vehicle : Insignia
    Trim : SE
    Engine : 2.0
    Year : 2011
    Quote Originally Posted by Triple Trouble
    stop doing handbrake turns or if ur lass drives it tell her to take handbrake off b4 she goes.
    South East
    B's used to wear rears alot as well.
    Regular Member installer's Avatar
    Nottingham
    Quote Originally Posted by storey_3000
    Dosen`t stop it though.Had new discs pads all round (warranty) and still rear brakes make that minor noise.
    Have been told it`s make up of pads etc that make them noisey too.
  1. brake grinding noise
    By li4m in forum Suspension, Wheels & Brakes
    Last Post: 29th July 2010, 20:54
  2. hand brake noise problem
    By pmitchell in forum Vectra C / Signum Car Chat
    Last Post: 26th July 2010, 12:56
  3. Noise from brake caliper?
    By byebyeitsagsi in forum Suspension, Wheels & Brakes
    Last Post: 1st April 2009, 12:06
  4. brake noise
    By willoftoon in forum Suspension, Wheels & Brakes
    Last Post: 25th October 2008, 00:54
  5. rear brake noise??
    By dezzie in forum Vectra C / Signum Car Chat
    Last Post: 17th May 2006, 03:54
