Thread: Do Astra and vectra hve same wheel fitments ?
    Regular Member no1baggiesfan's Avatar
    Jan 2008
    Newcastle
    Vehicle : 1.8 VVT SRi
    Default Do Astra and vectra hve same wheel fitments ?
    hi all,
    Ok, may sound a stupid question but im curious, looked around the net but cant find any difinative answers.
    Im looking at some alloys that are fitted to an Astra H 2007 5 stud, is this the same pdc (110) as the veccy c ? has anyone else fitted wheels from/to astra/vectra ?
    Cheers.
    WGAF#5
    im running astra alloys - albiet 16's but there astra's
    Birmingham
    Fitments are usually the same, its just the tyre sizes that are different, profiles me thinks!
    Bye bye Vec B
    - Hello Siggy!
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Astra Profiles are normally 5% less than the vec
    Sep 2009
    Belfast
    I changed my steel wheels on my 2008 Vectra Estate for 2008 Astra Coupe alloys. The tyres are the same size - 205/55/16. Just changed the bolts for ones that are a bit longer.
    I found the below site helpful.
    http://www.carlsalter.com/wheel_fitments.html
    I've actually now 4 x spare tyres for when the tyres on the alloys need changed. changed.
    Jan 2008
    Newcastle
    thanks for these replys guys, the wheels in question are 18s with 225-40-18 tyres, I currently run 225-55-16 so not much difference in wheel diameter (-6mm) according to:
    http://www.etyres.co.uk/tyre-size-calculator.htm
    So maybe a step up to 45`s might make the ride smoother with ony a 17mm increase.
    My main worry was the offset question, but if they fit an astra they should fit the Vectra easy, vectra offset 35-45 the same as the astra 5 stud 98-03, but newer astras were not listed on the http://www.carlsalter.com/wheel_fitments.html chart.
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    the astra H and the vectra c both have the same pcd
    Sep 2009
    Belfast
    You need to be careful as your speedo my not read correctly.
    Use the attached website to check your standard wheel size against what you are looking to put on. As long as you know the difference you can make the allowance to stay away from Mr Plod speed gun.
    http://www.alloywheels.com/tyrecalc.asp
    the speedo will change with different size tyres
    Jan 2008
    Newcastle
    only a 2.64% increase with 45's on
    leaving on the 40's is a -1% so nothing really to worry about either way.
  1. Vectra/astra zafira wheel fitment?
    By MarkP in forum Suspension, Wheels & Brakes
    Last Post: 7th February 2011, 14:49
  2. Wheel fitments
    By marley in forum Styling
    Last Post: 8th March 2009, 23:07
  3. Wheel fitments
    By keith1983 in forum Styling
    Last Post: 5th January 2009, 23:29
  4. Alloy wheel fitments
    By goonturbo in forum Suspension, Wheels & Brakes
    Last Post: 17th December 2008, 01:59
  5. Wheel Fitments Table
    By Caterman in forum Handling & Braking
    Last Post: 20th April 2008, 11:48
