Thread: Recall ??
    Regular Member silverhairedracer's Avatar
    ESSEX
    Default Recall ??
    I took my car in to the stealers this morning to have some trivial matter looked at,and on the booking in sheet they had also put down to do some recall work,which would take half a day,[so it goes back next tues]evident it is somthing to do with the bulkhead sealing,so if no one else is aware might be worth asking.
    In addition to the recall work they also have to re-programme my keys they do not unlock the boot without unlocking the doors first,
    Mar 2007
    North East
    From what I've read some of the earlier Insignias were a little light on some sealant on the bulkhead and developed leaks.
    Sheffield
    mine went in for some minor work and a mod was applied to remove the squeaking from the trim, absolutely silent now. Plus it needs to go back for another mod with parts on order, not sure what though
    Nov 2009
    lincoln
    there are so many recalls on the insignia's. many are minor and dont require parts like this one. there is no point inquiring about them as you will get a letter in the post if necessary and if your car goes in for any routine work a VX care sheet will be printed and any recall then mentioned to you or carried out straight away.
  1. BMW Recall!!!!!
    By Das in forum Comedy & Humour
    Last Post: 10th December 2012, 05:56
  2. F.P.R recall
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 27th January 2012, 22:02
  3. Recall
    By Tam80 in forum Vectra C / Signum Car Chat
    Last Post: 30th June 2011, 21:30
  4. was there a recall on dpf
    By iasha in forum Engine & Drivetrain
    Last Post: 23rd November 2009, 14:22
  5. AFL recall?
    By janc in forum Vectra C / Signum Car Chat
    Last Post: 27th April 2008, 17:48
