Thread: Gray smoke cold start
    Oct 2009
    SLOUGH
    Default Gray smoke cold start
    Hi everyone please help. I have a vectra 2.0 dti o3 plate. When i start my car in the mornings it struggles to fire up, but after about 10 seconds it will start. But a cloud of gray smoke comes out from exhaust. I have charged the glow plugs at weekend but the problem is still there anyone have any ideas what might be the fault. Please . Thanks antchris5
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    if its only first thing then its ok all day could be injector leak off pipes or injector seals.
    Regular Member Telly Addict's Avatar
    Sep 2009
    Fife
    Vehicle : BMW e92 335d
    Trim : M Sport
    Engine : 3.0 TT
    Sounds glow plug related, maybe check out the relay?
    Oct 2009
    SLOUGH
    ok thanks silly question how do i find out if there is a prob with the relay
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    on the average day the glow plugs would not come on any way, don't think they come on until low temperatures, you may see the light come on and off straight away but wouldn't come on until (don't quote me) about 0 / -3 , put a meter on the feed wire to the plugs from cold and get someone to turn the key. may have an initial 9v then drops down to lower voltage.
    Sep 2009
    Fife
    Trim : M Sport
    Engine : 3.0 TT
    Is that not just the indicator? I have noticed that there is tremendous current drain in my veccy immediately after starting as if the glow plugs were being heated, try the wash/wipe on yours and see if the same - it's quite slow initially then after a few seconds it increases to normal speed. That indicates to me that the glow plugs are on...
    I was under the impression that all the newer generation diesels had a much improved startup by designing the glow plugs to provide instant heat, with just on particularly cold starts an indication that you should allow a few seconds to preheat.
  1. smoke at cold cold start
    By azacbr6 in forum Engine & Drivetrain
    Last Post: 5th December 2012, 18:23
  2. Blue smoke from cold start
    By Ebbey in forum Vectra C / Signum Troubleshooting
    Last Post: 5th May 2012, 16:53
  3. White smoke on cold start up, 1.9 diesel
    By Fruit'n'nut in forum Engine & Drivetrain
    Last Post: 16th June 2009, 10:17
  4. Lots of Blue smoke on start up when cold?
    By VXR CDTi in forum Engine & Drivetrain
    Last Post: 17th February 2008, 15:14
  5. White Smoke - Cold start
    By DG01 in forum Vectra C / Signum Car Chat
    Last Post: 15th November 2007, 21:12
