Results 1 to 2 of 2
Thread: Vectra C SRI Wheel Allignment
    Regular Member dudley6623's Avatar
    Sep 2009
    skegness lincolnshire
    Trim : SRI
    Engine : 2.0L Turbo
    Year : 04/54
    Mileage : 88000
    Default Vectra C SRI Wheel Allignment
    Been today to get my vectra c sri tracked and balanced, balanced fine but when it came to the tracking/alignment the guy said that they couldnt adjust the rear because the adjuster bolt that goes thro a small arm had seized because the rubber bearing had worn, they reccomend changeing both sides, does anyone no what these arms are called or better still a vaux part number or link to someone that sells them.
    many thanks
    As far as I am aware the rear can't be adjusted for tracking alignment
    if it is out then that suggests the bushes themselves are worn
    However, you can adjust the camber but is NOT recommended, unless all the components in the rear suspension are in good order
    I've never seen rear tracking that is spot on, so long as both sides are the same value then leave it alone
    Mine is currently -0.35' on both sides
  1. 4 wheel allignment
    By pompey-pimp in forum Vectra C / Signum Car Chat
    Last Post: 15th April 2012, 11:53
  2. trackace diy wheel allignment
    By Al 22 dti in forum The 'Off Topic' room
    Last Post: 9th June 2011, 21:55
  3. Headlight allignment?
    By JSYSH466Y in forum Electrical & ICE (including SatNav)
    Last Post: 22nd May 2009, 09:15
  4. New NCTs and allignment done
    By Stuarty in forum Vectra C / Signum Car Chat
    Last Post: 15th January 2008, 18:56
  5. Post lowering allignment
    By Penfold in forum Vectra C / Signum Car Chat
    Last Post: 5th January 2008, 12:44
