Results 1 to 10 of 11
Thread: Changed BOTH Upper Control Arms - still knocks!!
    Regular Member si_hoss's Avatar
    Apr 2009
    Stevenage, Herts
    Default Changed BOTH Upper Control Arms - still knocks!!
    Hey all,
    I changed both my upper control arms from the How2 on here as they were seriously banging and the MOT was due, so clanking/banging gone now, however I seem to be getting a different, quieter rattle/knock from the rear, I think more from the off side wheel.
    The car passed the MOT with flying colours last week (only needed two front anti-roll links) so leads me to believe it's nothing major - but has anyone got any ideas what it maybe? My exhaust was a bit loose I noted when hitting it with the ratchet, but it's not an exhaust kinda sound, and again not picked up on the MOT.
    Where should I start looking??
    Cambridgeshire
    Have you tried taking everything out of your boot and removing the parcel shelf then taking it for a drive?
    I've found that my 'knocking' goes away when the parcel shelf is removed, not sure where it's knocking or what's it's knocking against...grrr
    Apr 2009
    Stevenage, Herts
    Quote Originally Posted by parsco View Post
    You know - I thought about the parcel shelf but never thought long enough to try it lol.
    I'll be doing that on the way home tonight then!!!! Good idea!!!
    Apr 2009
    Stevenage, Herts
    Right then - tried that last night, still knocks/rattles, no difference.
    It's totally liveable, especially as it's far less than before I changed the control arms. Just wondered if there could be any other common faults.
    Ashington, Northumberland
    Check your boot lock. They had a habit of not being adjusted properly and the boot would rattle. On the 'hook' part on the inside of the boot compartment, there are two bolts, undo them and move the hook downwards, tighten the bolts and give it a run
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    I think I may have that problem as i've noticed a creaking noise from the back of the car, especially when on uneven roads i.e the chassis is twisting slightly
    Oct 2007
    nottingham
    Default bushes
    Quote Originally Posted by si_hoss View Post
    hi had the same problem as you,i changed the arms and still had the noise. then changed the anti roll bushes and this cured the knock completly.only cost ten pounds to do myself.
    hope this helps tommy
    Apr 2009
    Stevenage, Herts
    Quote Originally Posted by tommy tess View Post
    Ok I'll change those next, I bought them when doing the arms, but the arms took so long time was running out, and I couldn't prise the damn thing apart so thought I was gonna brake the bridle (which wouldn't be good).
    I'll try again next time I'm free, cheers
    Apr 2009
    Stevenage, Herts
    Quote Originally Posted by GARY3306 View Post
    Thanks - I'll give this a go too, although I check the boot lid everytime I shut it to check it's closed properly and it doesn't move, but worth a go cheers!
    Regular Member denzilbud's Avatar
    cambridge
    anti roll bar bushes
  1. Other than rear upper arms and arbs what else knocks?
    By MCD in forum Suspension, Wheels & Brakes
    Last Post: 6th March 2013, 18:15
  2. Upper control arms
    By BigWilko in forum Suspension, Wheels & Brakes
    Last Post: 28th December 2012, 18:47
  3. upper control arms
    By chris1804 in forum Suspension, Wheels & Brakes
    Last Post: 30th September 2012, 18:55
  4. upper control arms
    Last Post: 7th May 2012, 14:22
  5. Could it be my upper control arms ?
    By Teza in forum Vectra C / Signum Car Chat
    Last Post: 28th January 2009, 19:03
