Thread: 2.0DTi Starting issues.. Really need some HELP
    Plymouth
    Default 2.0DTi Starting issues.. Really need some HELP
    Hi All..
    Ive got a problem that has me stumped!!
    I've got a 2.0Dti 54Plate 40k, Last service in August at aprox 36-37k (Full service fuel filter etc)
    The Glow Plugs were not changed.
    In the past 2-3 weeks Ive noticed it is having trouble starting when Its been left at work for a few hours..
    The car is parked on a slight hill.. nothing major just 5degrees ish.
    It doesnt matter if its nose up or nose down.. still the same effect.
    If the car is cold it will not start on the first turn and hold of the key.. even up to 10-15 turns of the engine. (15-20 seconds approx),
    However it will start if i then try again after the 2nd or 3rd turn..
    It never ever does this when parked on the flat at home.
    It doesnt matter if its 20c or 11.5c outside.. its always the same.
    Ive had a look around the leak off pipes.. theres no obv leaking.
    GlowPlugs are not due to be replaced till 80k.
    Ive tried turning on the ignition for 20 seconds before starting... even if the glowplug light does not come on..
    There are no warning lights, and the car runs fine when running.
    Has anyone got any ideas???
    Plymouth
    Regular Member suggs1971's Avatar
    east cleveland
    Hi my veccy 2.0 dti did the same turned out to be the leak off pipes on mine. Common fault when i did a search on here. Do you get a bit of smoke when it eventually starts?
    Oct 2007
    Wolverhampton
    My glow plugs didn't make it to 80k on my 04 2.0DTi. So assuming it's been in daily use I wouldn't be surprised if 1 or more are on the way out by now. It has been 5 years.
    Plymouth
    Quote Originally Posted by suggs1971 View Post
    Cheers.. Yeah i get some smoke out the back too..
    Quote Originally Posted by Munter View Post
    Cheers once again.. i think its a case of try all the cheap things and hope for the best
  1. Thermo/ Temp issues 2.0DTi
    By OpelVectraC in forum Vectra C / Signum Car Chat
    Last Post: 10th February 2012, 17:31
  2. Starting issues !!!!!
    By Dimscreen in forum Engine & Drivetrain
    Last Post: 4th May 2011, 08:09
  3. 2.0dti Not Starting
    By rossgetty in forum Engine & Drivetrain
    Last Post: 27th March 2010, 20:14
  4. 2.0DTi - Fuel/startng issues (again)
    By Led in forum Vectra C / Signum Car Chat
    Last Post: 31st October 2009, 18:04
  5. 2.0dti non starting
    By richc in forum Engine & Drivetrain
    Last Post: 1st June 2008, 22:01
