Results 1 to 10 of 13
Thread: Cars booked in for investigations !
    Forum Moderator FIL 4822's Avatar
    On a French Carp lake somewhere x
    6 Post(s)
    Vehicle : Insignia VX-line RED Tourer
    Trim : No, over weight!
    Engine : Flux Core Capacitor
    Year : 1 A.D
    Mileage : Rising
    confused Cars booked in for investigations !
    I've noticed over the last few weeks that there was a certain amount of 'play' creaping in with my steering. There is about 4-5mm of movement in the steering wheel when turned side to side before i can feel any resistance.
    The car has started to steer itself so i suspect its either the rack or track rod ends have started to wear at less than 24000 miles and 2 1/2 years old.
    Its quite un-nerving aswell when you brake hard, as the car changes direction slightly with no movement on the steering wheel.
    I'll await the outcome of the investigations......
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Mmmmm I get this sometimes too. Must really take a look myself
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    me too but have changed all the droplinks and trackrod ends etc and it still sometimes steers itself but have been told its the profile of the tyres that makes it does that
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    yip - lower profile tyres will certainly make it tramline - i.e. follow groves in the road etc - my 18" wheels on the saab were terrible for that.
    Actual play in the steering wheel tho i.e. you turn the wheel a cm etc without it doing anything normally means a worn rack.
    Are you VXR Enough
    13 Post(s)
    well ive no play in that area but bit concerned that we have inner track rod ends??
    Full Member Robsey's Avatar
    North East Cheshire
    21 Post(s)
    Trim : Energy
    Mileage : 131,000
    Mine wanders when my tyre pressures are even slightly down...3 or 4 lb or so....
    But then again I have granny clampet standard 16" alloys.
    I would have thought low profiles would be less susceptible to vagueness / wandering.
    Regular Member Kcs's Avatar
    Feb 2007
    Tamworth
    Try looking at the pinch bolt that holds the bottom of the steering
    column to the rack spline, mine came loose and gave me about 4-5 mm
    of play in the steering wheel ! the teq just tightened it back up.
    Regular Member mattDY57's Avatar
    Yorkshire
    Quote Originally Posted by Kcs View Post
    Had exactly the same problem with mine.
    Feb 2007
    Tamworth
    Quote Originally Posted by mattDY57 View Post
    Did you get your Vec from Niddvale by any chance ! ! !
    Full Member Big Sig's Avatar
    Mine was like that, had wear in the UJ where it enters the steering rack.
  1. Cars booked into body shop
    By pipamish in forum Vectra C / Signum Car Chat
    Last Post: 12th April 2012, 21:10
  2. Guess what the cars just been booked in for
    By bobssignum in forum Styling
    Last Post: 4th May 2009, 18:53
  3. Just booked in my car...
    By _ZS_ in forum Vectra C / Signum Car Chat
    Last Post: 18th February 2009, 22:57
  4. Cars booked in !
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 12th January 2009, 14:40
  5. Cars booked in the bodyshop next week....
    By The Doc in forum Vectra C / Signum Car Chat
    Last Post: 8th March 2006, 13:06
