Thread: Cruise control
    Regular Member suggs1971's Avatar
    east cleveland
    Default Cruise control
    Well thanks to this forum again ive found the problem with my cruise control, broken clutch return spring, found a bit of spring hanging off the clutch pedal. Rang vauxhall and picking up a modification spring for £8.60 this afternoon. Happy days.
    Regular Member danlat1415's Avatar
    Lancashire
    I've just picked mine up today.
    I'm having problems fitting it.
    I've been rolling around in the footwell, and I can see where I think it's supposed to go.
    In the pack, you get the spring, and a little yellow clip.
    Behind the clutch, a bit higher up, then is a metal bar, with a hole in it, where the yellow clip fits perfectly.
    I've then tried compressing the spring, and putting on end in the yellow clip, and the other end at back of the clutch pedal, but even with the spring fully compressed, it's too long to fit between the gap.
    Am I putting it in the right place?
    Regular Member gangleyshag's Avatar
    Jul 2009
    kidderminster
    mines got same problem, ive gotta go buy one to fit
    WGAF#5
    might be a good time for a how2 to be compiled whilst people are experiencing problems
    Regular Member old cruiser's Avatar
    slough
    Quote Originally Posted by danlat1415 View Post
    Hi mate , take a look at this thread and the photos, it might help you, did mine last year and fitted ok, had to pull up on the clutch pedal a bit to help get it in if I remember correctly http://forum.vectra-c.com/showthread...=clutch+spring
    Cheers Pete
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    i dont want to hijack the thread but ive just had a vectra c how does the cruise control work?
    reason i ask ive been on motoway and turned it on but when i tap it up to go faster it goes up but when i keep my finger on it, it cuts CC,
    can somebody tell me how it works
    11 Post(s)
    Quote Originally Posted by chris1804 View Post
    east cleveland
    Hi danlat1415. Just fitted my clutch return spring this morning. If you pull the clutch pedal up the bottom end of the spring will fit in. There is a notch on the back of the clutch pedal. Cruise control here i come.
    Lancashire
    I managed to get mine fitted last night, after a few scratches, and getting covered in the spring grease, after it came apart a few times.
    Wonder if my CC work now... I also took the indicator stalk off, and cleaned the contacts.
    Mine has never worked, so will be a bonus.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    tried to get my ind/cruise stalk came off but could not see ,i know it can be easy via 2mm allen key. my stalk moves about 1mm, when i pull it outwards and press cruise it works, but if the stalk is moved it dont.
  1. Cruise Control
    By tony100la in forum Vectra C / Signum Car Chat
    Last Post: 7th March 2010, 19:43
  2. cruise control
    By stuart bigboy in forum Electrical & ICE (including SatNav)
    Last Post: 26th May 2008, 21:14
  3. Cruise Control
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 12th May 2008, 17:36
  4. manual control or cruise control.
    By johnm in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2008, 14:20
  5. Cruise Control not there?
    By Robsey in forum Electrical & ICE (including SatNav)
    Last Post: 1st February 2007, 18:23
