Thread: Coolant issues
    Regular Member Adz86's Avatar
    Aug 2009
    West Yorkshire
    Default Coolant issues
    The coolant symbol has flashed up a few times since getting my water pump done, checked the level of fluid, says in the book it should be half way up the container when engine is off, which it does look like to me, is there a possibility there could be something wrong with the pump and therefore making the car think there's not enough coolant in? If this isn't the case what us the problem likely to be? And what problems could the problem result in
    Regular Member carpet's Avatar
    Jul 2006
    TENTERDEN KENT
    I have had a problem like this it turned out to be a dodgy/loose/dirty connector, worth checking them all.
    Regular Member Swaite53's Avatar
    South Wales
    There is a marker on the coolant bottle. A line and the word Kalt (German for cold). When the engine is off and cold, the fluid should be on this line.
    If the fluid is below the line, then top it up and keep an eye on it. They can be quite sensitive, so if it's just slightly below the line, topping it up may sort it. If it drops below the line again, then there is a leak somewhere.
    Regular Member barkzz's Avatar
    I had a leak thanks the water pump begining to seize on my old 1.8, the leak was so small however that under hot running conditions it was evaporating away not leaving a trace.
    Once the cambelt and water pump were done, the leak corrected itself, and also the temperature gauge started to behave like normal
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    How many miles since the water pump was changed? Does the car run hot, cold or normal since the wp change?
    Posible air lock?
    Aug 2009
    West Yorkshire
    About 350 miles, gona take it to garage that did it today and ask them to have a look
  1. Coolant
    By tubby in forum Engine & Drivetrain
    Last Post: 16th November 2012, 21:36
  2. coolant
    By reeseandellie in forum Engine & Drivetrain
    Last Post: 29th August 2012, 15:39
  3. Coolant Cap?!?
    By jordib in forum Vectra C / Signum Car Chat
    Last Post: 5th March 2010, 20:59
  4. Coolant
    By Bloicy 3.2 V6 GSI in forum Engine & Drivetrain
    Last Post: 23rd August 2009, 12:19
  5. coolant top up
    By pyro_maniac in forum Vectra C / Signum Car Chat
    Last Post: 26th December 2007, 00:58
