Results 1 to 10 of 13
Thread: diesel fuel filter
    Regular Member jpdtm's Avatar
    southern ireland
    Default diesel fuel filter
    Just a quick question ? Where abouts is it on a 1.9 cdti sri 120. Thanks for the help .
    Nottinghamshire
    It's the round black plastic cylinder that sits inside a metal cage attached to the bulkhead behind the engine. It has 2 fuel pipes (in and out) and 2 electrical connectors (heater and water sensor). The fuel pipes are attached with the usual quick-release clips and the electrical connectors just clip on as well.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Is this in a similar location on the 150 CDTi, been meaning to change mine for a bit now.
    southern ireland
    Sound for that, must hav a look for that some day during the week .
    Regular Member Telly Addict's Avatar
    Sep 2009
    Fife
    Vehicle : BMW e92 335d
    Trim : M Sport
    Engine : 3.0 TT
    Yep, you can just see it in this photo. The alternator is resting against it.
    Nottinghamshire
    Yes, it's in the same place on the 120 and the 150.
    For anyone who seaches the forums wondering where the diesel filter is on the older DTi's, it's on the nearside of the bulkhead inbetween the coolant expansion tank and the ABS unit. Also, it only has one electrical connector - there's no water sensor.
    southern ireland
    Thanks a lot for the photo. Funny i just had to get the alternator replaced and was wondering what that part was at the top with all the pipes going in to it, makes sense now.
    Regular Member sidturbo's Avatar
    burnley
    can anybody tell me if there is a special way of tightenin the black plastic cap up that holds the filter in cos mine is seaping diesel out since i changed the filter, just cant seem to get it tight enough and yes i have fitted the new seal that came with the filter.
    sorry to jump on somebody elses post!!!
    Nottinghamshire
    Quote Originally Posted by sidturbo View Post
    DTi or CDTi?
    I have the DTi and it's just the Torx screw in the middle to the torque value moulded in the plastic next to it. There are 2 seals and it can be tricky to seat the top one correctly - it likes to pop out when you're trying to get the top back on.
    I'm not sure about the CDTi one - I know that the top screws directly onto the body rather than being held on by a Torx screw. Perhaps check the seal (s) is/are seated properly and that the top is torqued up right.
    burnley
    Quote Originally Posted by James24 View Post
    DTi or CDTi?
    cdti mate
  1. Air in the fuel filter on 3.0 V6 Diesel - Help!!
    By NPS in forum Engine & Drivetrain
    Last Post: 25th October 2012, 18:25
  2. Diesel fuel filter
    By john1 in forum Engine & Drivetrain
    Last Post: 16th March 2009, 23:29
  3. How do you drain the diesel fuel filter of water
    By chrisvectra in forum Vectra C / Signum Car Chat
    Last Post: 26th November 2008, 11:04
  4. diesel Fuel filter
    By PeteRs in forum Vectra C / Signum Car Chat
    Last Post: 1st June 2008, 21:18
  5. Diesel fuel filter
    By Trhains in forum Engine & Drivetrain
    Last Post: 28th May 2007, 16:44
