Results 1 to 10 of 15
Thread: twang from near side front coil
    Regular Member denzilbud's Avatar
    cambridge
    Default twang from near side front coil
    as title i know that this has prob been asked a million times but ive got a twanging sound coming from coil spring ive had the car up on a jack and checked everything gave the coil a real good tug and nothing,checked each side to make sure but nothing,its getting worse so any ideas would be great
    Rad mounts or drop links. Most likely those, hopefully you checked the spring was intact?
    cambridge
    i will be changing those at some point mate but this sound definatly sounds like a spring
    Jun 2009
    N. Ireland
    Sounds like a top strut bearing had to do this on mine
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Are their little plastic sleeves on the bottom coil of the spring? If not thats your problem, they only cost a few quid from VX
    I was just about to suggest the spring mod!
    WGAF#5
    when does the twagning sound occur ??
    i.e. when the vehicle is stationary and you turn the steering wheel from lock to lock ??
    Blantyre
    I get it when i turn left
    WGAF#5
    Quote Originally Posted by spennny View Post
    suspect the spring is moving on the mount - have you got the spring sheaths fitted ?
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    can vx tell you if i've got them fitted on my car if i ring them?
  1. twang twang BANG !
    By gsxrster in forum Vectra C / Signum Car Chat
    Last Post: 11th March 2012, 21:27
  2. front coil springs
    By davidlewis24 in forum Vectra C / Signum Car Chat
    Last Post: 5th April 2011, 17:59
  3. Twang noise from front?
    By melvin in forum Suspension, Wheels & Brakes
    Last Post: 12th December 2010, 12:40
  4. front coil springs ?
    Last Post: 2nd May 2008, 20:40
