Thread: creaking from the front
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    Default creaking from the front
    hi everyone new here, got myself a vectra c friday the 2.0dti 2005 prefacelift one
    the only fault i can say about it is
    when going over a speed hump the ones that cover the whole road when coming down them it creaks like mad, ive read about the radiator mounts ive sprayed them with wd40 tonight but ill have to see if that does the trick, the cars just passed MOT 24th Aug 2009 cars been sitting for 6 weeks at dealer ship, any ideas on what it could be?
    Oct 2009
    Sandwell
    anybody?
    Regular Member deanos's Avatar
    UK
    Vehicle : Insignia
    Engine : 2.0
    Year : 2011
    Could be its needs sleeves on the front springs, i had mine done under warranty and now it dosent creak.
    Try putting some grease spray at the bottom of the springs that can help.
    New Member Rapier's Avatar
    Oct 2009
    Norfolk
    Exclamation
    I had a similar creaking noise on mine. It was a crack in the top part of the suspension mount. Eventually the centre shaft of the strut broke through the top mount and whacked into the bonnet.
    When I opened the bonnet (to find out what the noise was) the right-hand
    side strut centre shaft slowly lifted up out of the front wing.
    If was pretty cheap to fix. Got new top plates for the top mounts fitted at the local car repair place. The guy that fitted them said the new ones were thicker and strong than the original ones.
    I was lucky that I was only doing 5mph - and the bonnet was not damaged.
    The left side mount was cracked too.
    Mine is a 2003 - so hopefully yours has the new design but you might want to check. Maybe someone more knowledgeable then me will post the answer.
    Oct 2009
    Sandwell
    got some more info, today i thought i would try each side of the car when i went over speed hump on the right side no noise was hurd same with left side, only when car was centre of speed hump and went over the noise came back any ideas?????? i will try spraying some wd40 at the botton of the springs when i get time, i contacted vx today asking them about spring mod they aint hurd of it lol
    Full Member Robsey's Avatar
    North East Cheshire
    14 Post(s)
    Trim : Energy
    Mileage : 131,000
    Good old Vx.... they haven't heard about problems with road springs, top mounts and all the other faults that we have been moaning about for the last six years..!!
    Oct 2009
    Sandwell
    the best one was i contact sandwell vx asking them he said there is an outstanding recall on your car for handbrake i said ok ill get it booked in, i contated brinley (tipton) i asked them about mod they never hurd of it so i asked the about the recall on my car the guy said said no there ISNT any outstanding, lol jokers, take it they dont want to do the work
    East Midlands
    Right..the main culprit for the noise you have when going over speed bumps.
    1/Front anti roll bar bushes....cheap fix, can diy if your allright with the spanners..look for the How To.
    2/Front drop link bushes....again cheapish fix,and a doddle to do.
    3/ Rad mounts...as above.
    4/ Front springs shagged.
    5/ Front shockers knakered.
    Start from number 1 above and work your way down the list until it's fixed...GL.
    Oct 2009
    Sandwell
    Quote Originally Posted by macdad View Post
    its turned into a crunch sort of sound now so out of the top 5 what wouldyou say, ive seen the how 2 for 1&2 but im abit puzzled with how2 for ARB bushes, where can i find them?????
  1. creaking front end
    By Swedge in forum Suspension, Wheels & Brakes
    Last Post: 10th October 2012, 11:15
  2. creaking front end
    By peadar in forum Suspension, Wheels & Brakes
    Last Post: 30th September 2009, 22:13
  3. creaking from front end
    By tony whin in forum Suspension, Wheels & Brakes
    Last Post: 23rd February 2009, 21:53
  4. Creaking from front
    By johnmac in forum Suspension, Wheels & Brakes
    Last Post: 8th December 2008, 22:16
  5. Creaking from front - 03 1.8 SXI
    By addyboy1982 in forum Suspension, Wheels & Brakes
    Last Post: 13th June 2007, 21:14
