Thread: web/laptop help.
    Regular Member Ean's Avatar
    Suffolk
    Question web/laptop help.
    Hello ello!
    I have an ickle web book, works very well, most sites, work well, and run fine.
    Although i have difficulty with some, and i get a message flash up 'out of virtual memory'
    how can i stop this happening? i am not very pc literate, sorry,
    Hope to hear from a pc bod soon!
    Whoop!!
    Ta, Ian.
    Ok, your computer (however small) runs in the momry. This is also known as RAM, and these days about 2GB is normal, although yours is probably smaller (1GB, 512 MB etc). All the computer programs run in this memory as it's much faster than the hard drive the programs are actually stored on. It's similar in construction to the SD cards that you put in your camera...
    If you have a lot of programs running, the computer will run out of memory and start slowing down, as it has to constantly move programs in and out of memory to and from the hard drive to be able to run. In these situations, it uses a part of the hard drive itself as memory, and this is known as Virtual Memory. Unfortunately, it runs about 100-1000 times slower than proper RAM...
    If you've run out of that, then you've either got some serious amount of programs running, or a virus of some sort is causing taking it all up by running in the backround..
    Good news is, you can increase the amount of space it is allocated on the hard drive. A quick google will tell you how for your operating system. I'd find it myself, bu tea's ready...
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Send me a PM mate with your Number if you need some help and ill talk you through everything. Will have to be tomorrow though im afraid.
    Stephen
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    What O/S is it running? Windows XP or Windows Vista??
    Windows Vista has a service called Superfetch which has been known to take a lot of memory up that is doesn't need to as it caches what it thinks are programs you will use into memory before you actually use them. I normally disable this on Vista.
    asdasd
    If its a notebook then it will only be Windows XP and will only have 1gb Ram..
    Suffolk
    Yeah, its a note book, with XP running. :-) one of the Eee PC? Asus Eee PC 701SD
    WGAF#5
    i know where all looking at the technical side of the problems -but as a simple solution wasnt there an option on XP whereby if you plugged in a memory stick that it could use it as memory for the computer? this would then add to the memory and allow Ian to free up some "virtual Memory" and carry on surfing
  1. laptop help
    By neill in forum The 'Off Topic' room
    Last Post: 10th August 2011, 22:27
  2. Laptop for car
    By lizard in forum General Chat
    Last Post: 13th June 2011, 17:28
  3. laptop
    By fjaimo10 in forum Vectra C / Signum Car Chat
    Last Post: 9th June 2011, 20:46
  4. PC, well Laptop help please.
    By Green Growler in forum General Chat
    Last Post: 4th June 2008, 19:42
