Thread: iso fitting
    Jul 2009
    loch lomond
    Default iso fitting
    hi can you please help
    i am wiring my double din dvd player and have noticed the ignition 12+ is missing can someone please tell me were i can take a safe feed as i don't want to use lighter socket as mine dont work unless ignition is fully on.
    mine is a 2.2 2002 elegance
    many thanks
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    you can find it in the fusebox.. but have you swithec round the red and yellow wire on the back of the ISO block? thats neede to put aftermarked in..
    Jul 2009
    loch lomond
    hi there no my 12+ battery is fine its the acc 12+ feed i am looking for
    cheers
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    As such there is no Accessory Ignition position on the ignition switch...
    Just permanent live (red).
    Ignition Live (black)
    And separate from the ignition switch, there is a live when lights are on (Usually grey with yellow or green tracer).
    There is a how to on VxON forum about making an Acc position on the ignition switch, but I've never checked this out...never really had to..
    Jul 2009
    loch lomond
    does anyone know what fuse will become live when acc is turned on?
    thanks
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Vauxhalls aren't wired up with an Accessory position, therefore you would have to make your own, via the ignition switch...
    So in answer, until you make up your own accessory spur...None of the fuses become live in the accessory position.
    Jul 2009
    loch lomond
    yes it does! i turn my ignition to acc and alot of things power up clock lights windows even the footbrake light then one more turn the ignition comes on then other turn to start the car
    Administrator plasma's Avatar
    On the Forum
    359 Post(s)
    Engine : 150
    Mileage : 74000
    try the ciggy lighter, thats on when the ignition is on only
    Jul 2009
    loch lomond
    yeah had it on that before but its not suitable as i am parked alot in the car
    il figure it out the morra cheers for replies apretiate it
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    I stand corrected, but none of my 3 vauxhalls have had an Accessory position,
    They were Cav 2 (1987), Cav 3 (1994) and Vec C (2005).
    Mine all have either off or ignition on.
    What would be 1st position for mine simply unlocks the steering lock.
    Apologies if you thought I was being a numpty...just basing my knowledge on my 20 yrs experience as a Vx owner.
    Coming back to your query then...
    The clue lies in what becomes live in the Accessory position on your car.
    You would then need to look in your handbook for the relevant fuses...although again, apologies if you have tried this already.
    I'm trying to look at this in a logical manner.
  1. hid fitting
    By mrk in forum Vectra C / Signum Car Chat
    Last Post: 7th February 2011, 18:25
  2. USB fitting
    By chinarose87 in forum Electrical & ICE (including SatNav)
    Last Post: 10th March 2010, 17:21
  3. When im fitting
    By PAULMAC77 in forum Styling
    Last Post: 3rd April 2009, 15:30
  4. fitting a PS2
    By steeb82 in forum Electrical & ICE (including SatNav)
    Last Post: 15th December 2008, 09:30
