Thread: CDC 40 Opera - Confused
    Sep 2009
    Stratford-upon-Avon
    Default CDC 40 Opera - Confused
    Hi, Just won a CDC Opera on fleabay, with screen and DAB aerial, all taken out of the same car, I have searched several threads on here, but have found contradicting info, wonder if someone can clear this up for me.
    As the screen and HU have come from the same car, will they just plug into my car (currently have CD30 not mp3), or will i need tech2? some threads on here state that i would need tech2, others say i dont and it will just plug and play
    Thanks people!!
    Regular Member willc01's Avatar
    UK Motorway Network + some smaller roads
    They will go straight in without Tech2 as they are already paired. Did you get the seperate DAB box? as this is not in the radio.
    Sep 2009
    Stratford-upon-Avon
    Brilliant thanks for that! It comes with seperate aerial with a small black box attached so I assume this is the DAB box? Does this also mean that the BC will be enabled or will it need tech2 for that?
    Feb 2006
    Dorset
    Dab box lives at the back of the glove box at the end of the fuse board , has a single multi plug going to it and a fakra terminated ariel , without it no DAB
    Full Member Robsey's Avatar
    North East Cheshire
    30 Post(s)
    Trim : Energy
    Mileage : 150,000
    BC functions usually are enabled on units with the GID or CID screens.
    Yours should be GID, and therefore it SHOULD be enabled.
    Regarding the DAB, some CDC40's came with it, some didn't.
    As said above, you should have a third piece to have DAB...(a black box with a white fakra plug socket on it and a wiring loom to link it to power and canbus system)
    Otherwise you will get standard AM and FM reception.
    Regarding tech 2....no it should just go straight into your car.
    However radios not married into your car, with your cars radio pass code, will often make crackling or popping noises through the speakers for the first five minutes after switching off the radio...
    Just an annoyance more than anything else!!
  1. cd 40 opera
    By landynigel in forum Electrical & ICE (including SatNav)
    Last Post: 12th September 2012, 20:59
  2. Help please with CDC 40 opera
    By Jason_899 in forum Electrical & ICE (including SatNav)
    Last Post: 2nd December 2011, 18:26
  3. CDC 40 Opera are they all DAB??
    By merikiito in forum Electrical & ICE (including SatNav)
    Last Post: 29th February 2008, 16:25
  4. Cdc 40 Opera
    By Eddie Dee in forum Electrical & ICE (including SatNav)
    Last Post: 28th February 2007, 18:59
