Thread: Front Calipers
    May 2008
    Scottish Highlands
    Default Front Calipers
    Hopefully someone can help me again here.....went to change all my discs and pads today to discover that there is a Torx Bolt on the calipers. Now i thought it was an E20 but on inspection....it's not, it's the female bolt not a male.
    What the heck?
    Regular Member darko2301's Avatar
    Croatia
    well mate there are both types..
    red ones are the ones you talk about and green ones are the ones which need to be un-done in order to remove the caliper..
    the ones you meant (female) are used to separate 2 parts of the caliper, do not touch them
    HTH
    May 2008
    Scottish Highlands
    cheers bud...my calipers don't look like that lol
    Allan
    Croatia
    i believe the principle is the same mate.. just take a better look
    It's the black plastic bits you need to take off to find the female torx bolts to seperate the caliper from the carrier...
    Croatia
    yes, but he has to remove the carriers as well in order to change the discs..
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Quote Originally Posted by Penfold101 View Post
    But they aren't torx bolts they require a 7mm allen key
    You're absolutely right - how on earth did I manage to say that when I changed two sets last weekend for Andy W...
    Croatia
    this way u'll understand better:
    red-the bolts which you are talking about?
    green-black bits which penfold is talking about
    blue- the bolts which hold the caliper attached to the axle..
  1. £80 for 3.0 v6 front calipers shall i?
    By 06sri in forum Suspension, Wheels & Brakes
    Last Post: 3rd September 2014, 20:10
  2. are 3.2 v6 front calipers the same as 1.9 cdti front calipers
    By gazturbo in forum Handling & Braking
    Last Post: 5th May 2010, 19:11
  3. Front calipers from SRI
    By parsco in forum Parts for sale
    Last Post: 22nd April 2009, 11:20
  4. front calipers? back calipers?
    By kenny1zero in forum Handling & Braking
    Last Post: 19th July 2008, 08:11
  5. front brake calipers from a 1.9 sri
    By aerodynamic18 in forum Parts for sale
    Last Post: 2nd June 2008, 11:25
