Thread: VECTRA AUTO STICKING IN 5th GEAR
    Oct 2009
    lINCOLNSHIRE
    Default VECTRA AUTO STICKING IN 5th GEAR
    Hi All,
    I became the owner of a vectra elite today, unfortunately I already have problems with the auto box and cruise control !!!
    Its been fine on the journey home, but noticed the problem when i came to overtake a car and there was no kickdown, when I'm driving it sticks in 5th, when you try to change it manually it also stays in 5th, whatever you do it will only re-set if you turn ignition off and back on again. But problem comes back very quickly. Anyone have any ideas ??
    Also the cruise control seems to be intermittant, sometimes work and oherimes teh light just flicks up and dissapears quickly. Tried pulling the brake pedal up but makes no difference, could the stalk be faulty ???
    I'm going to ring the garage back up tommorw and tell them the issues, just wanted some suggestions of the solution ??
    Jon
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Where do you want to start ?
    As far as high on the list goes :
    Incorrect fluid level
    Faulty Transmission ECU / firmware
    Damaged/faulty selector switch
    Internal Transmission fault/failure
    If it's still under any kind of dealer/garage warranty the best thing you can do is get it back in there for them to sort out. The odd mention of any goods being 'fit for purpose' under consumer protection laws might be useful if they start suggesting it'll cost you.
    Oct 2009
    lINCOLNSHIRE
    Garage are taking the car back to have a look, they suggested a faulty solenoid, but we'll see !!!
    When it comes back, check the fluid in the autobox just to make sure its not pink like milkshake!
    Oct 2009
    lINCOLNSHIRE
    I suggested the oil too, and he said there were a number of things they could try, hopefully they will sort it and it lasts longer than 6 hours !!
    Oct 2009
    lINCOLNSHIRE
    Just to confirm, i assume the 'milkshake' consistancy is due to that coolant issue i've been reading about. ??
  1. Vectra C Auto Gearbox - Jumps While Going From 3rd to 2nd Gear
    By Tigra16V in forum Engine & Drivetrain
    Last Post: 13th September 2012, 15:33
  2. Vectra C Sticking Gear Shift
    By Shamal in forum Engine & Drivetrain
    Last Post: 1st August 2011, 00:40
  3. 1.9 CDTi Auto Box Sticking
    By s-owen4 in forum Engine & Drivetrain
    Last Post: 27th September 2010, 21:20
  4. 2004 3.2 V6 Vectra misses auto gear change
    By hodger in forum Engine & Drivetrain
    Last Post: 24th May 2009, 12:51
  5. Sticking Auto Box
    By Gersh in forum Engine & Drivetrain
    Last Post: 26th December 2008, 10:47
