Thread: egr possibly?
    darlo
    Default egr possibly?
    rite guys when i fire my 1.9cdti 150 up sumtimes it pulls rite from low revs quick and smooth the other times its slow and very clunky
    darlo
    so could it be the egr thanx if any 1 can help
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Sounds like the EGR is 'sticking', but the CDTI's have never been good with low down torque.
    Gazza4
    Have you driven diesels before?
    If you need to accelerate then you need to drive the car in the "power band", unlike a petrol
    This is even more essential in a turbo diesel, where you need to have the engine at about 2000rpm
    If you are doing this, or this issue has suddenly appeared, then from reading about the 1.9 CDTI there are some known problems which result in erratic power availability
    I'm quite sure someone with a 1.9 CDTI can confirm this, but swirl flaps seem to be the most common cause
    If the car is still under warranty (up to 3 years / 60K miles) or Network Q then get down to a VX dealership and have them look at it
    If the car is out of warranty, then wait until the problem is more permanent and hopefully a fault code is recorded
    Phone around and get some quotes for a diagnosis and TEC2, prices vary from "free" to £150
    Quote Originally Posted by Gazza4 View Post
    Perhaps you mean the 1.9 CDTI as mine works fine at high gear / low torque
    I can even drive at 30mph in 6th gear, just don't expect rapid acceleration!
    darlo
    yeah had 1.7dti astra befor the vec and always acel to 2000 rpm befor gear change its just a pain when it works fine then its lumpy and had manifold changed how much can i get a new egr for
    Could be the swirl valves too, have you checked? You may find a few keys from your key board in there too
    darlo
    had swirl valves replaced and im terible for missing letters
    well that rules them out then. As above, give the EGR a clean before you replace it as some have had good results with this.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Both. Also with regards to your comment regarding swirl flaps, they only affect performance over 2,500rpm and either cause smoking or low or high up the rev range depending whether they are closed or open.
    Gazza4
    With a failed EGR you usually get an unusual noise, similar to rushing water
    Are you getting that?
    Equally, has there been an increase in smoke?
    It is also possible that the replacement swirl valves have failed or affected something else
    One of these typical things, if it ain't broke don't fix
    When you do fix something it was actually something else that was causing that problem!
  1. Could it possibly be???
    By BigWilko in forum Electrical & ICE (including SatNav)
    Last Post: 30th December 2012, 20:51
  2. First (and possibly last) mod
    By rockh in forum Insignia car chat
    Last Post: 3rd June 2009, 19:53
  3. MLC possibly ?
    By FIL 4822 in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 16th November 2008, 19:07
  4. Possibly a new car for me ?
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 20th December 2007, 20:30
