Results 1 to 10 of 13
Thread: Power sounder batterys.
    Regular Member suggs1971's Avatar
    east cleveland
    Default Power sounder batterys.
    Just to let people know ive found a company that sells the batteries that are fitted to the power sounder on a veccy c. Ive been having problems with my car alarm going off on my veccy c 2.0 dti 52 Reg and found out on this site that the power sounder has internal batteries which go dead after a while so i removed the power sounder and got a screw driver to it, it came apart very easily, took out the battery pack which is 4 varta 1.2 volts 240 mAh Ni-MH type 55625. The company is called Batterytastic part of the Cell Pack Solutions company based in south shields, they sell the batteries seperatly for £2.00 + vat, im going to ring the company on monday as they can custom build battery packs which would make it easier. Once i have more details i will put it on the forum.
    Hope this is of interest.
    east cleveland
    Default Update to power sounder batteries
    Hi all ive been in touch with a company called Cell Pack Solutions based in South Shields. They sell the internal batteries fitted to the power sounder found in the left side of the boot. The price would be around £12.00 + p+p which i think isnt bad considering the cost of a new unit from vauxhall. Ive been asked to post my old battery pack so they can make the new pack.
    [Ex]Admin Duncan's Avatar
    That's a good find! With my last car (Astra G) the battery started to go in the sounder and it would 'chirp' each time the ignition was turned off (it's way of letting you know the batteries were low) and the dealer said that they were sealed units and batteries couldn't be replaced. IIRC the same applied to the batteries in the Vec C / Signum (according to the dealer) so that's good to know!
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    I think thats what happened to my dti but instead of replacing the sounder/batteries they just threw it in the bin and now all there is, is a multiplug. Sorry but the lights don't flash loud enough to make up for the lack of a sounder.
    So if I buy a second hand one and the batteries are nackered i'll p.m you
    east cleveland
    No probs, the company i sent the old battery pack to should have received them today so crossing fingers. It is a big con of vauxhall as the 4 batterys are only larger type of a watch cell battery which is connected by a small connector to the circuit board.
    People have managed to crack them open and replace the batteries.
    http://www.astraownersclub.com/vb/sh...ad.php?t=96753
    Scroll down to "In the Wheel Arches" section, and then click on 'How To'..... Replace the Power Sounder
    east cleveland
    Hi all. Just received the new battery pack for the power sounder on my veccy c from Cell Pack Solutions today £12.10 inc vat and p+p. gonna fit it tomorrow and hopefully no more alarm problems.
    east cleveland
    Fitted the battery pack to the power sounder on my veccy today and it works, was definatly the problem i had with the alarm going off. I connected the main plug to the power sounder, set the alarm then disconnected the plug again, the power sounder went off running off the internal batteries so job done.
    Oct 2010
    Aberdeen
    Hello, Just want to ask, do u still remember what is the size of the batteries and how many of them in the battery pack ?
    Cos I'm planning to get few batteries from Cell Pack Solutions and make a pack by my own, Cell Pack Solutions get same type of batteries with volts and mAh, I just need the size. holpfully it will be ok.
    Thank you very much.
    Jun 2006
    Kirkintilloch, Scotland
    What please is the typical life folk experiencing for the power sounder batteries? 6 years?
    Thanks,
    Dave
  1. Power sounder problem
    By namalundu in forum Electrical & ICE (including SatNav)
    Last Post: 11th February 2013, 22:02
  2. Changing power sounder and its loctaion (In a Signum)
    Last Post: 17th February 2011, 18:41
  3. Power Sounder
    By Hursty103 in forum Electrical & ICE (including SatNav)
    Last Post: 14th February 2011, 10:40
  4. key fob batterys
    By denzilbud in forum Vectra C / Signum Car Chat
    Last Post: 21st June 2009, 18:37
vectra c power sounder location
vauxhall power sounder battery
zafira gsi power sounder
vectra c alarm battery location
astra mk4 power sounder
how to remove power sounder vectrac hatchback
power sounder alarm draining battery
astra g power sounder batteries
https:www.vectra-c.comforumshowthread.php92917-Power-sounder-batterys
Alarm - power sounder battery needing replaced
power sounder corsa c
powersounder
power sounder battery replacement
2008 vauxhall vectra power sounder
power sounder battery vectra
vectra c power sounder battery
new vauxhall power sounder
