Likes Likes:  2
Page 1 of 5 123 ... LastLast
Results 1 to 10 of 43
Thread: Fuel filter change on a 1.8 petrol
    Regular Member danlat1415's Avatar
    Lancashire
    Default Fuel filter change on a 1.8 petrol
    Hi guys,
    I'm planning on changing the fuel filter on my Vectra.
    I've got the filter, but just not sure how to replace it.
    I've checked through the service history, and I cannot see that it has ever been replaced.
    I've had the car 4 years so far, and it's currently at 94k miles, so guessing it would benefit from a filter change.
    I've checked the HOW2 section, and I can't see that one has been done for the filter (requested, but not yet on there).
    Does anyone know how to change the filter?
    When I do mine, I'll take photos etc, so I can add it to the How2 section.
    Dan
    Sunny Dartmoor
    I would like to know this aswell,so some one must know.
    Regular Member al21784's Avatar
    Jun 2007
    Batley, West Yorkshire
    Vehicle : Vectra c
    Engine : 1.9 CDTI 150
    Year : 06
    Mileage : 193000
    Hey guys ,
    It's fairly straight forward and simple, the fuel filter has 2 clips at either end, squeeze the little plastic clips together and the petrol line will come off (eventually ), repeat for the other end .
    Replacing the filter is so simple, it will just push onto the fuel line at either side.
    Obviously a little bit of fuel will come out thats in the filter it's self but it wont drain your tank
    AL
    Sunny Dartmoor
    Thanks AL,where abouts is it situated?
    Jun 2007
    Vehicle : Vectra c
    Year : 06
    Mileage : 193000
    Quote Originally Posted by glenboy View Post
    Not a problem
    It's on the off side near the rear wheel arch, you may need to jack the car up to be able to see what your doing properly as it is a pain for a start
    The first one will take ages, the second one will be so easy once you've figured it out
    AL
    Lancashire
    Thanks for the advise.
    Do you need any special tools, or need to do anything special to remove it from the car? I don't want to break anything, as the fuel is a pretty bit deal.
    Also, do I need to put some fuel in the new filter before connecting it, or is it ok with air in?
    Jun 2007
    Vehicle : Vectra c
    Year : 06
    Mileage : 193000
    Quote Originally Posted by danlat1415 View Post
    I used a pair of needle nose pliers, you've basically got to push the plastic clips in and pull it out, you can use your fingers if you can push it together
    I didn't bother trying to fill it up with fuel tbh, just connected it and it's never had a problem , when you switch your ignition on, the fuel pump primes the line anyway
    AL
    Jul 2009
    sussex
    easy job!
    make sure its the right way round going back on though.
    May 2008
    Tyneside
    Best to release the fuel pressure first with the schrader valve on the fuel injecter manifold, just looks like a tyre valve. Last time I didn't bother and got an eyeful of petrol.
    Lancashire
    Quote Originally Posted by al21784 View Post
    AL
    I tried using needle nose pliers to hold the clips in at the end, in order to pull the hose off, put it won't budge.
    I don't want to keep messing with it because i'm worried about breaking the end of the hose.
    As you can see from my photo, mine is really old, and definatly needs replacing (it's at least 4 years old. Maybe even been on car since new - 7 years, 52 plate.)
  1. Petrol Fuel Filter
    By wafoo in forum Engine & Drivetrain
    Last Post: 9th August 2012, 19:36
  2. New Fuel Filter - Petrol Models
    By SRiXPT in forum Parts for sale
    Last Post: 5th July 2011, 19:23
  3. Fuel Filter - Petrol
    By siadwel in forum Vectra C / Signum Car Chat
    Last Post: 20th June 2011, 11:21
  4. fuel filter help petrol PLEASE
    By vwsaxon in forum Vectra C / Signum Car Chat
    Last Post: 12th April 2011, 18:51
  5. Fuel filter - petrol
    Last Post: 6th December 2010, 14:31
vectra c fuel filter change
vectra fuel filter
vectra c 1.8 fuel filter
vauxhall vectra fuel filter replacement
https:www.vectra-c.comforumshowthread.php92888-Fuel-filter-change-on-a-1-8-petrolpage3
fuel filter location vectra club
vectra c fuel filter replacement
vectra fuel filter pictures
changing fuel filter on vectra petrol
vectra c fuel filter location
vauxhall vectra 1.8 fuel filter location
how to fit fuel ffillter on a petrol vauxhall vectra estatehow to change fuel filter on vectra chow to replace vectra c fuel filterfuel filter change on vectra c.1.8 o8 plate can u replace a snapped fuel filter clip on a 05 plate vectrahow to change a fuel filter on a Vauxhall vectraopel corsa bakkie fuel filtervectra c 1.8 fuel filter changepetrol filter vectra cschematic diagram of opel corsa lite fuel filter and fittingschanging fuel filter vectra cwhere is fuel filter on vectra c
