Thread: intercooler pipe
    Apr 2009
    lincolnshire
    Default intercooler pipe
    hi, my 2.0 dti has gone into limp mode yet again due to what was diagnosed as a dodgy maf but after replacement it made no difference. fault was then traced to the top intercooler pipe which has split. im told you have to buy the whole pipe set up and cant get just the bit i need, is this correct. i was thinking about getting a stainless steel and silicone job made up, afterall it cant be any more than what vx want to charge me. has anybody else taken this route?
    Apr 2009
    liverpool
    You do have to get the two pipes and the connecting plastic tube from a VX dealer, around £80 od.... It's probably worth replacing both anyway, as the bottom will likely fail sometime after the top.....
    So unless anyone comes on with an alternative, that's the way to go....
    Hunwick, County Durham.
    Trim : Elegance
    Engine : 2.0T
    Mileage : 59.4K,
    mine had a split in it around an inch long. i just repaired the pipe with some heat shrink tubing from work. if you want a couple of lenghts for the pipe drop me a PM and i will send some out. mine has done 8K on the repair and no signs of it going again. mick.
    Apr 2009
    lincolnshire
    Quote Originally Posted by mick 1986 View Post
    thanks for the offer, i'll let you you know if all doesnt go to plan. i had a word with my local stainless exhaust place about replacing the current set up. he thinks it should be easy enough and not to expensive, he's gonna have a look monday.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Apr 2009
    lincolnshire
    its the other side i need.
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Apr 2009
    lincolnshire
    thats the one. im gonna look into the silicone and stainless first though. its good to know there are other options out there. think im gonna change the rubber bit of the oil pipe that runs across the top of the engine too as it looks like the jubilee has dug into it quite badly and almost gone through.
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Just a side note to say those ones are silicone
    Apr 2009
    lincolnshire
    had it sorted very cheaply today. cut out the split bit and put some stainless tube in. only cost me £20, much better than vx's £80 + vat. my garage took the eml off for nothing too.
  1. Should these fit over my intercooler pipe?
    By Alank in forum Vectra C / Signum Car Chat
    Last Post: 2nd June 2011, 18:00
  2. is this an intercooler pipe?
    By richje100 in forum Engine & Drivetrain
    Last Post: 25th February 2011, 06:11
  3. intercooler pipe
    By tigertye in forum Engine & Drivetrain
    Last Post: 3rd October 2010, 12:29
  4. Intercooler Pipe, HELP!
    By joewin1975 in forum Engine & Drivetrain
    Last Post: 22nd October 2008, 21:02
