Thread: Z18XE Owners please
    Sep 2009
    Audley STAFFS
    Default Z18XE Owners please
    Hello, a quick question, I have a 04 1.8 sxi,the only issue I have with this car is,, it seems low geared in 5th, my last vec a 2000 1.6 was doing 2600rpm at 70mph and felt quite a bit more relaxed than my sxi, which is doing 68mph at 3000 rpm. so What rpm is your 1.8 petrol doing at 70 mph?
    I have a rpm calculator which tells me my gear box is a f17 wide ratio, but I have been in a another 1.8sxi (same year as mine) and his was doing 75mph at 3000 rpm, we both checked or speedo with a sat nav, and found them to be near spot on ot 60mph,
    SO the question,, what rpm is your 1.8 petrol doing at 70 mph?,
    thanks ANT.
    Sunny Dartmoor
    I'll check and get back to you.......
    Sep 2009
    Audley STAFFS
    Quote Originally Posted by glenboy View Post
    thanks glenboy
    Sep 2009
    Audley STAFFS
    Quote Originally Posted by CLOMP View Post
    thanks ANT.
    EDIT, Acording to sat nav, I was holding 3000 rpm in 5th, speed was 69.4mph
    hull
    my sxi is the same mate, 3000rpm @70mph.
    it uses the same box as the sri in the sxi, closer ratios with slightly better 0-60 times.
    Sunny Dartmoor
    Checked mine today and was doing 3000rpm a 70mph.........
    Sep 2009
    Audley STAFFS
    ok thanks for the replys,
  1. Z18XE using oil
    By damers2000 in forum Engine & Drivetrain
    Last Post: 5th August 2012, 11:48
  2. Z18XE using oil...
    By danBoy in forum Engine & Drivetrain
    Last Post: 24th April 2010, 10:41
  3. !!!Attention all diesel owners!!! (Petrol owners may want a look too!)
    By John LE in forum Vectra C / Signum Car Chat
    Last Post: 18th April 2009, 20:56
  4. Z18xe
    By Ridah in forum Vectra C / Signum Car Chat
    Last Post: 22nd April 2008, 10:33
  5. Z18xe?
    By Matt21385 in forum Vectra C / Signum Car Chat
    Last Post: 27th October 2006, 07:48
Z18xe 3000rpm problem
