Results 1 to 3 of 3
Thread: engine problem
    Nov 2005
    northern ireland
    Default engine problem
    hey guys havnt been about 4 a while, havin problems with my engine when i start the car after a few seconds the car starts 2 judder and vibrate then returns 2 normal revs, also im havin a dead spot before the turbo kicks in it seems to have no power then takes off after 2000revs and lots of black smoke its a 2004 vectra 1.9cdti
    any ideas??? thanks
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    120 or 150, 120 egr needs a clean /150 swirl flap rod + egr needs cleaning. plenty of posts on site for guidance try the how to section there's egr and boost sensor cleaning in there, also a guide to fix your swirl flap bar for a few quid.
    Apr 2009
    liverpool
    If you're not mechanically minded. or too skint for a garage pocket emptying session.......put some Millers additive in a tank of the expensive diesel, and then take the car for a thrash, hard through the gears...........theres a good chance that'll clean it out enough to get your performance back. Works for me
  1. problem with engine
    By stroake in forum Engine & Drivetrain
    Last Post: 13th May 2009, 18:36
  2. Vec C 1.9CDTi 150 engine problem
    By ROCKATANSKY in forum Diesel Engine related
    Last Post: 1st February 2009, 14:19
  3. Cdti 150 Engine Problem
    By scad2k in forum Vectra C / Signum Troubleshooting
    Last Post: 25th August 2008, 21:31
  4. Problem when turning engine off!
    By user999998 in forum Engine & Drivetrain
    Last Post: 17th June 2008, 01:25
  5. 2.2 Engine problem
    By hamish178 in forum Engine & Drivetrain
    Last Post: 8th November 2007, 00:40
