Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: interior light
    sheffield
    Default interior light
    i've been having trouble with my interior light, it's never worked since i've bought the car, i've tried new bulbs and recently changed it over to a completely different unit (£20 off ebay including sunglasses holder so bought it anyway as it was a bargain) but nothing seems to work. The boot light, glovebox light and dashboard lights all work so i dont think it's the fuse. Can anyone please help?
    sheffield
    any tips on taking the headlining down so i can take a look? any ideas what i should look for?
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Try check the boot, around the fusebox to see if they unpluged it!
    sheffield
    had a look in the boot but couldn't see anything obvious, any ideas which fuses i need to check?
    Engine : 2.2 Direct
    Sorry want the fuse i ment.. but actually the ribbon cabel.. about 2 inches wide and very flat.. that goes up in to the roof at the C-pillar..
    If you also have rainsensor then you should have 2 flat ribbon cabels attached in the REC.
    (i dont know what fuse it is)
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Is there a rear passenger light fitted?
    sheffield
    no i haven't got a rear light fitted. I cant see a ribbon cable going into the fusebox in the the boot, should i check the fusebox in the passenger side door? thanks for your help guys
    sheffield
    Quote Originally Posted by kenp View Post
    sorry REC? rear electrical control? i was looking for the ribbon cable but can't see it at all. I know what you mean cause i've seen it when i took the light out. it's like greaseproof paper with copper printed on it but all i could see in the boot was fuses
    Engine : 2.2 Direct
    REC = rear electric module.
    you should be able to see the hole and there should be a ribbon cabel.. and you remove what hides it for you.. (ive got a estate.. not sure its the same to remove as saloon/Hatch)
    sheffield
    the carpeted thing?
  1. interior light
    By jamiedvvt in forum Bodywork & Interior
    Last Post: 19th November 2012, 17:47
  2. Interior Light - 4th light switch blank ?
    By Woody in forum Electrical & ICE (including SatNav)
    Last Post: 12th November 2012, 23:44
  3. Interior Light Issue - Light & Button Illumination?
    By Leemarksmith in forum Electrical & ICE (including SatNav)
    Last Post: 7th November 2012, 23:36
  4. URGENT:Glovebox Light/Interior Light Fuse
    By Hendry in forum Vectra C / Signum Car Chat
    Last Post: 5th June 2011, 09:13
  5. interior light
    By chrosty in forum Bodywork & Interior
    Last Post: 6th April 2011, 23:06
