Results 1 to 10 of 30
Thread: 2.0T Intercooler?
    Jan 2006
    Dalriada
    Default 2.0T Intercooler?
    Has anyone changed the standard cooler on their 2.0T? The reason i ask is that i spoke to MPG yesterday and they mentioned they can fit bigger cooler's to the NET.
    So anyone done it and is it a worthwhile mod??
    Wales, UK
    Not sure but I thought I heard that they run the same intercoolers as the VXR, in which case its plenty big enough, with no improvemtns to gain ??!!?? I might be wrong !
    There would be very little to gain on a std one, but on a tuned one it maybe worth it
    Jan 2006
    Dalriada
    They actually told me it was uprated to a VXR cooler, so im assuming they must be different?
    Regular Member blue estate's Avatar
    oh well.. I tried..
    I've done it.. took out the standard cooler.. moved back the aircon rad and added a universal front mounted ally cooler.. got pipework sorted and away you go
    Jan 2006
    Dalriada
    Have you noticed any benefit's with fitting the larger unit??
    oh well.. I tried..
    Pulls smoother and harder and seems to run cooler... about 85 degrees rather 90 degrees
    Hmm, mine has always run bang on 85 degrees whether it was standard, S1 or S3. Wonder if it would run less than that with a second or larger intercooler.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    You dont really want to make them larger, just more efficient, the larger the internal volume the longer it takes to get up to boost. Yes you may get more power in the end but at the sacrifice of response and drivability.
    Jan 2006
    Dalriada
    Cheers for the info Craig
    Mine run's at around 85 degrees too Duncan and this was not affected by the superchip's map which i really need to get it back to standard...
  1. intercooler?
    By justin32 in forum Engine & Drivetrain
    Last Post: 19th January 2013, 17:09
  2. Intercooler
    By beat275 in forum Vectra C / Signum Car Chat
    Last Post: 2nd January 2012, 12:36
  3. Standard intercooler v front mount intercooler
    By tommytonguedj in forum Engine & Drivetrain
    Last Post: 29th June 2011, 09:58
  4. Intercooler
    By user999998 in forum Engine & Drivetrain
    Last Post: 16th May 2008, 11:02
2005 saab 9 3 b207l front mount intercooler upgrade
opel signum td04l max hp
how to make the vectra standard intercooler more efficient
b207l exhaust manifold noise
saab 9-3 downpipe ferrita
how much bhp can a standard intercooler take on a 2.0t vectra c
