Thread: My spanner is always on.....??
    Regular Member smiley-sri's Avatar
    Jul 2009
    Tamworth
    Default My spanner is always on.....??
    Ive got a 55plate pre face lift cdti 120.
    When im driving the "engine" Symbol is never on but the large spanner stays on permantly. How an i find out its probablem??
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP NAV
    Engine : 1.9 CDTi 150
    Is it due a service..?
    Full Member Big Sig's Avatar
    Thats an oil can not a spanner iirc. Have you checked your manual to correctly id the symbol just to make sure? If its a fault light then you need to get the codes read. hth
    Lancashire
    Trim : XP NAV
    Mine displays a spanner when its due a service...
    Regular Member Swaite53's Avatar
    South Wales
    Is the spanner in an outline of a car? If so, this is engine electronics.
    Or, is the spanner over an oil can? If so, it requires a service, but should only light briefly when the engine is started and again when turned off, not permanently.
    I don't think mine displays the spanner only symbol for anything.
    Are you sure? Without getting a manual I thought it is as below?
    Quote Originally Posted by Swaite53 View Post
    EVERYWHERE
    Quote Originally Posted by smiley-sri View Post
    Get the codes read.
    Either take it to your VX dealer (take your wallet with you,unless it's got a warranty..on second thoughts,take it anyway),or take it to your local 'do-it-all' garage.They'll find the problem using their diagnostic equipment for a small fee,but may not have a clue as to what the 'real' problem is.
  1. Help - Spanner, then no spanner!
    By Ricksh in forum Engine & Drivetrain
    Last Post: 1st October 2012, 12:04
  2. Oil can/spanner 1.000 .what is this mean?
    By Dobs in forum Engine & Drivetrain
    Last Post: 9th April 2011, 20:26
  3. Spanner
    By BigWilko in forum Electrical & ICE (including SatNav)
    Last Post: 15th December 2010, 20:09
  4. car with spanner going through it?
    By monty2000 in forum Electrical & ICE (including SatNav)
    Last Post: 15th June 2010, 13:00
  5. Oil can with spanner
    By Darryl2.2DTI in forum Electrical & ICE (including SatNav)
    Last Post: 21st May 2009, 01:14
