Results 1 to 10 of 21
Thread: Fitting 2nd hand Vectra C satnav (I don't have any codes)
    Oct 2009
    Hampshire
    Default Fitting 2nd hand Vectra C satnav (I don't have any codes)
    Hi guys,
    Just bought a Vectra C SRi with satnav, but the headunit is missing. I have just bought a NAV70 headunit from eBay, the auction reads 'IM NOT SURE IF THIS UNIT HAS BEEN DIVORSED FROM THE ORIGNAL CAR AS I BOUGHT IT FROM A BREAKERS'.
    So assuming the worst scenario what will I need to do? I don't have any manuals/codes for my vehicle!
    Any help will be much appreciated, thanks!
    11 Post(s)
    If it hasn't been divorved from the donor car, nor supplied with the screen from the donor card, you've just purchased an expensive door stop.
    Basically the unit should have been put back into delivery mode (which means it was divorced from the car it was fitted to) so that you can then have it married up to your car via a Tech2 code reader.
    If it has been put into delivery mode, then all you need do is apply to Vauxhall for the Car Pass (£15 to £20) for your car which will have the necessary codes so it can be married up to your car.
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    If is hasn't been divorced then you can get a radio company that specializes it getting codes from CD** radios to read the code,then its just a matter of Tech2
    Irmscher Insignia CDTI 130
    Oct 2009
    Hampshire
    I doubt it's been divorced. God, what a rigmarole!
    They usually go for around £230-£250 on eBay, n I got this one for £175 delivered, so another £30-£40 won't be too bad I guess. :/
    11 Post(s)
    Quote Originally Posted by chodecz View Post
    Plus the Tech2 session for the marriage ceromony. Another £40 to £70 depending on where you get it done.
    Regular Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Firstly, from my own experience, I would
    Fit the head-unit and give it a whirl...
    If it works then it is still paired / married. The downside is that you will not be able to program changes to it's functions. It wil more than likely crackle and pop on your speakers for the first five minutes after switch off, however this is more an annoyance than anything else.
    If it is unpaired / divorced then it will flash up "safe mode" on your display and ping every 5 seconds or so.
    You will need to find someone with Tech 2 (forum member or Vx dealer) to have it programmed in (paired up / married into your car).
    Although this will cost you for the programming in at a Vx dealer, you should have no future programming or popping issues.
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    And lets not forget a few good scrappys have Tech2 and do un-pair parts,i now of a couple that do this
    Oct 2009
    Hampshire
    Many thanks for the info!
    Does anyone know someone who can do the TECH2 programming cheap??
    Also, what is the PASS CODE??
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    It's the card that comes with the car when it's new, it also has the key number on it and is normally in the folder with the books
    Full Member Big Sig's Avatar
    you don't need a pass code on a full can bus head unit
  1. fitting a garmin satnav in place of cd30 gid screen?
    By Jow20 in forum Electrical & ICE (including SatNav)
    Last Post: 13th February 2012, 23:07
  2. Post codes in CD70 NAVI satnav - who has this working ?
    By eeyore in forum Electrical & ICE (including SatNav)
    Last Post: 6th October 2011, 16:09
  3. Vectra VXR with AFL and Satnav?
    By george1987 in forum Vectra C / Signum Car Chat
    Last Post: 23rd June 2011, 12:39
  4. Fitting satnav
    By declanswan in forum Electrical & ICE (including SatNav)
    Last Post: 14th February 2009, 18:56
  5. vectra c satnav
    By chris_20 in forum Vectra C / Signum Car Chat
    Last Post: 15th October 2008, 12:00
vectra c sat nav with all fittins for sale
fitting vectra satnav
tech2 fitting sat nav
fit sat nav in a vauxhall vectra c
