Thread: Clutch/Gearbox problem
    Jul 2009
    west midlands
    Default Clutch/Gearbox problem
    I have a 06 plate 2.2 direct elite petrol , I have noticed purely by chance that when changing gear from 2 - 3 and 3 - 4 there is a very very small crunch.
    I only noticed this because the radio was off and I had both front windows open, but now because I have noticed this problem it is the only way I drive and with winter coming I need to get it resolved before I catch hypothermia.
    Does anyone know what this is, and is it the start of anything major
    Regular Member Telly Addict's Avatar
    Sep 2009
    Fife
    Vehicle : BMW e92 335d
    Trim : M Sport
    Engine : 3.0 TT
    First thing I would try is a clutch fluid flush and gearbox oil change. You may find that cures it completely, or at least make it better.
    Jul 2009
    west midlands
    Thank's, I have seen the mechanic at work and he will do the deed for me on Saturday
    Regular Member PORKBALLS29's Avatar
    Epping
    Mine does the same, Is yours the 6 speed box?
    Jul 2009
    west midlands
    sorry,been on holiday, yes its the 6 speed box
    Regular Member Jezzy's Avatar
    S.E
    Are you sure it affects the gears you've mentioned? There's a known fault with the F40 transmission that it crunches a little when going from 1st to 2nd when the gearbox is cold, and then when it's warmed up it does it from 2nd to 3rd. Shouldn't affect 4th. If it's as I've described, Vauxhall's fix is to remove the 3.2 litres of oil that are in the gearbox and replace it with 2.4 litres, (you can't just remove 0.8 litres, as there's no dipstick for measuring the level). However, Vauxhall also say that if the gearbox already only has 2.4 litres in it, then there's no further fix available.
    Regular Member barkzz's Avatar
    Mines like this on the CDTI 150. Exactly as you menion it.
    4th 5th 6th all fine. 1st and 2nd groggy when cold, as are 2nd to 3rd when warmer.
    Regular Member nigec's Avatar
    barnsley
    Yep mines as above, same car same gear changes.
  1. gearbox and clutch
    By vectra craig in forum Engine & Drivetrain
    Last Post: 13th June 2012, 19:50
  2. Clutch?? Gearbox??
    By wingz123 in forum Vectra C / Signum Troubleshooting
    Last Post: 27th March 2011, 10:47
  3. New gearbox and clutch
    By 2.2direct-sri in forum Engine & Drivetrain
    Last Post: 21st July 2009, 13:52
  4. Clutch/Gearbox Noise
    By scott1uk in forum Engine & Drivetrain
    Last Post: 14th November 2008, 11:03
