Thread: oil& filter change 1.9 cdti (120) vectra est '05
    Regular Member bigsteve's Avatar
    Apr 2008
    Nottingham
    Default oil& filter change 1.9 cdti (120) vectra est '05
    Good evening all, I run a '05 vectra estate 1.9 cdti (120) and have it serviced annually at my local garage at a cost of £170... I have since covered 12k and thought I would have an intermediate oil change as I'm a little uneasy at the thought of going 20k between oil changes, I called my local vx dealer in Worksop,Notts, and they had to ring me back with a price to simply change the engine oil and filter....£87.60! Is this unreasonable, and what should I expect my local garage to charge?
    Also, where is the oil filter on this model...........do I have to undo the covers underneath to access it? help please.
    Bristol
    Vehicle : CDTI 150
    Hi,
    The oil filter, which is a paper cartridge, is located at the centre/rear of the engine and is only accessible from underneath.
    You will need to remove the undertray to gain access to the filter and sump plug. The sump plug requires a Torx drive. The oil filter housing is plastic and requires a large socket to undo, 36mm if I remember. Ensure you also get the seals. Also a good idea to get a new seal for the sump plug. Torque settings :Sump plug 20Nm Oil filter housing 15Nm. You will need 4.3 litres of 5W30 ACEA A3 / B3 for a standard change or GM-LL-A-025, GM-LL-B-025 for the longer service interval.
    Apr 2008
    Nottingham
    Many thanks lesj, will get on and sort it
    Wales
    Like what lesJ said. Also might be worth getting a new sump plug; they can round very easiliy. Sods law says if you dont get a new plug, you'll need one!
    You can get cheap (genuine vauxhall) oil form Autovaux - £20ish as opposed to the £40+ the dealer will charege you. A big saving. Bonus
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    DO NOT USE ANYTHING OTHER THAT FULLY SYNTHIC FOR ENGINES WITH A DIESEL PARTICULAR FILTER ! no matter how long between service intervals, vx only recomend lower grade oil for non particular models.(smll print in your service booklet).
    Professional Trader oilman's Avatar
    Nov 2005
    Cornwall
    Vehicle : Posche
    Trim : 928 S4
    Engine : 5.0
    Year : 1989
    You should be able to save money on an oil change by providing your own oil, look up your car here http://www.opieoils.co.uk/c-861-car-engine-oils.aspx
    You should find a suitable oil and filter service pack.
    Guy
    oilmans website : www.opieoils.co.uk/
    e-mail : oilman@opieoils.co.uk
    tel : 01209 215164
    Apr 2009
    Derby
    You'll need a 32mm socket/spanner for the oil filter cap.
  1. Oil filter change 1.9 cdti 150
    By Kcs in forum Vectra C / Signum Car Chat
    Last Post: 8th May 2011, 09:39
  2. vectra cdti sri fuel filter change????
    By Mads in forum Engine & Drivetrain
    Last Post: 20th March 2011, 22:50
  3. Oil filter change on a 3.0 cdti
    By marktaylor in forum Vectra C / Signum Car Chat
    Last Post: 1st March 2010, 18:40
  4. oil filter change 1.9 cdti vectra c
    By haggispie in forum Vectra C / Signum Car Chat
    Last Post: 18th June 2009, 19:37
  5. 3.0 cdti K & N Filter change
    By M&S in forum Vectra C / Signum Car Chat
    Last Post: 28th September 2006, 18:14
vectra c sri 120 sump bung
vauxhall vectra 1.9 cdti sri 120 how to change filter
