Thread: speed dial adjustment
    Regular Member darko2301's Avatar
    Croatia
    Default speed dial adjustment
    does any of you guys know if it it possible to adjust speed gauge to work with a specific background, eg if i put a background which has top speed of 260 or 280 instead of 240, is it possible via tech2 or somehow else to adjust the needle to show the right speed value?
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Funny you should say that mate as A member just got his SRi back and when it went in it had 170mph clocks and when it came out it had 160mph clocks, so it must be possible for the dealer to do it.
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    I would think there will be different speedo units available with different speed cards (miles only, KM only, miles & km) as well as differing speed ranges - lower top speed for lower trim levels/smaller cars, higher top speed for top end and high performance models.
    I'd assume the card and drive unit will be matched for calibration purposes. But I'm only guessing.
    Croatia
    rushy, do you maybe know if they've changed the whore dash unit , all clocks or he has just modified the background as i think if you swap complete clocks there is no need for any tech2 as they are already calibrated to work how they are supposed to but i'd leave the clocks alone and just change what's written under the needle
    handyandy, well i guess that if i swap for the opc (vxr) clocks they would work just fine, but if they've managed to get those to work up to 300kmh maybe they are just a few clicks away from enabling me to have the same thing..
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    I think they swapped the whole unit to try and fix a fault. Let me try and look for the thread.
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    LINKY to thread. Sorry mate not much info in the thread, might be worth a PM though.
    Croatia
    thanks for your effort rushy though there was no big help from the thread..
    i'll visit my dealer in few days anyway so i'll ask them
    still thanks
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    If you got a card you could line it up and see if the numbers line up with just the extra tacked onto the end?
  1. dial smd type
    By beat275 in forum Vectra C / Signum Car Chat
    Last Post: 5th February 2012, 20:32
  2. prob with heater fan speed dial
    By bobk1 in forum Bodywork & Interior
    Last Post: 22nd March 2011, 02:31
  3. Headlight adjustment dial
    By Ginge7289 in forum Electrical & ICE (including SatNav)
    Last Post: 8th February 2011, 19:19
  4. fan speed dial
    By larann in forum Electrical & ICE (including SatNav)
    Last Post: 28th September 2010, 21:54
  5. All Dial Failure!
    By j13hdb in forum Electrical & ICE (including SatNav)
    Last Post: 29th June 2010, 16:08
