Results 1 to 2 of 2
Thread: Long Brake Pedal Distance
    N
    Default Long Brake Pedal Distance
    Hi,
    So I finally got around to servicing the vectra and I also changed all discs/pads and bled new fluid around. I went out for a drive but the brakes really weren't up to much. They are almost the same as before which isn't too odd considering the old parts weren't in terrible condition.
    But I was expecting some difference and there is almost none? The brake pedal used to travel quite far down before you 'felt' the brakes being applied. I was hoping the full change including fluid would sort that out but they still need to be pressed down 10-20% before I even feel them! Also no signs of leaks in the system from a test - Pump pedal until firm with engine off, Start engine and the pedal sinks a bit but stays firm at a point, Switch off the engine and the pedal didn't sink at all. However when the engine is on, I can sometimes pump the pedal so it gets very firm at the top of the pedal travel, but other times I pump and it doesn't?
    I drove a 3 year old Auto VW Jetta and boy! It was only the baby diesel engine but even tapping the brake pedal a few mm you can feel it significantly. I was looking for something like that on the veccy though?
    Is this normal for the smaller Vectra brakes or do the pads just need bedding in before this will happen [driven 50-60miles]?
    N
    hump de bump
  2. For Sale: Vauxhall Insignia Brake Pedal Alloy Cover - SRI sports pedal cover
    Last Post: 20th December 2012, 21:36
  3. Brake pedal ?
    By Denbo in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2011, 01:47
  4. brake pedal
    By barrie m in forum Suspension, Wheels & Brakes
    Last Post: 12th February 2010, 21:21
  5. Long (ish) Brake Pedal Feel.....?????
    By Palmo in forum Suspension, Wheels & Brakes
    Last Post: 12th October 2008, 11:28
