Thread: servicing my z22se
    Regular Member denzilbud's Avatar
    cambridge
    Default servicing my z22se
    hi there just wonderd how or if you fill the oil filter cartridge when doing an oil change or do you just fill the engine run the engine and top up oil to correct level
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Pop it in dry, fill with oil, start then top up mate. Be sure to use a proper GM filter though mate, as the none GM ones can break down.
    PS, smear a little oil on the rubber seal
    cambridge
    cheers mate yeh got all the bits from vaux the other day also whilst your about mate,is it possible to wind the rear piston on the calipers with a pair of pliers or should i buy the tool
    Vehicle : SRi
    Mileage : 137000
    You can use a set of pin nose pliers while pushing in. I've never done it though as I bought the Tool so couldn't tell you how hard it is.
    cambridge
    cheers mate,mot coming up in november so getting bits sorted before hand
    Vehicle : SRi
    Mileage : 137000
    No worries, mine's in Feb, think I might need a new set of rear shocks.
  1. Z22se
    By Paddy in forum Engine & Drivetrain
    Last Post: 1st April 2011, 14:02
  2. z22se mpg
    By denzilbud in forum Vectra C / Signum Car Chat
    Last Post: 13th August 2009, 19:03
  3. vec c egr(z22se)
    By denzilbud in forum Engine & Drivetrain
    Last Post: 3rd July 2009, 11:36
  4. z22se in a vec c
    By benny in forum Engine & Drivetrain
    Last Post: 30th August 2007, 00:05
