Thread: Rattle clunking noise when revs drop to idle
    Regular Member pugs,signum's Avatar
    swansea
    Default Rattle clunking noise when revs drop to idle
    Hi,
    Im wordering if anyone can shed some light on an annoying sound i get when the car is ticking over and i give it a rev and let it settle to idle i get a rattling/clunking/knocking sound, iv had a look under the bonnet and had someone give it a rev and release to see if i can find the problem, if the clutch is fully pressed it makes the same sound also get same sound when starting the car in morning but this is only from time to time, its a signum 1.9 cdti (150) all runs fine except a slight jerk just after 2100 revs when cruising at those revs, i think this might be the third injector problem or a faulty temperature sensor that might be reading incorrect temperature resulting in an alteration of fuel to air mixture that in turn gives a slight jerk?
    found this thread and will try this out as it wont even cost £2
    http://www.vectra-c.com/forum/showth...exhaust+rattle
    thanks in advance
    pugs
    darlo
    i have the same problem i think it sounds like the exhaust nocking in it brackets let me know if u find what it is
    swansea
    confused
    Quote Originally Posted by gav_embo View Post
    What engine you got mate?
    After doing a lot of reading on here lastnight, it pionts to the DMF (dual mass flywheel) hoping this is not the problem as it costs around £1000 to do, i paid more attention to the sound today while driving home from work and i found that the sound stops when clutch is fully pressed to the floor eventhough i said otherwise yesterday! its been doing this for over a year but only now wondering what it is
    Admin plasma's Avatar
    On the Forum
    187 Post(s)
    Engine : 150
    Mileage : 74000
    Yep sounds like the DMF to me too. It will probably rattle a bit with your footing resting slightly on the clutch pedal and also on the rundown to idle
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    darlo
    1.9cdti 150 hope it not the dmf ive already had to do the inlet mani
    swansea
    Same engine as mine and your not alone there mate i did my inlet manifold in january costing over £600 thought about getting rid of it but i looked on auto trader and be lucky to get £4500 but i owe £5500 still so think id be better off sorting the dmf out in the new year n splash out a grand at least that way i know iv got a car with new swirl valves (inlet manifold) and a new dual mass flywheel that should last me so i can keep it for many years and run it into the ground.
    Or am i just ?
    darlo
    cost me 470 for manifold to be done as for the dmf that can wait a long long time to be done got to put 4 new tyres on it this week oh the joys ov motoring
  1. High idle revs
    By Kaz in forum Engine & Drivetrain
    Last Post: 15th December 2013, 23:18
  2. idle/low revs
    By srikev in forum Engine & Drivetrain
    Last Post: 2nd October 2012, 19:21
  3. Rough Idle and Low down revs
    By lofty in forum Vectra C / Signum Car Chat
    Last Post: 17th June 2011, 22:29
  4. Revs slow to drop
    By bazsignum in forum Vectra C / Signum Car Chat
    Last Post: 31st July 2009, 07:59
  5. Replies: 4
    Last Post: 12th December 2008, 12:47
droning noise from insignia when revs drop
rattling noise after revving engine vxr
Knocking noise as revs drop
vauxhall 1.9 cdti vectra rattles from bell housing on tick over disappears when reved
bump noise when revs drop
vectra rattle noise
vauxhall corsa rattle on idle
corsa vxr 2016 rattle on tick over
idle rattle noise 1.7 cdti vauxhall
vectra rattling noise on idle
vauxhall vectra rattling noise when idling
insignia rattles at idle
signum cdti knocking at idle
vauxhall signum noise when idling
vectra rattles on revs coming down
insignia clunk noise on idle
Vectra c rattle idle
