Thread: 2 problems need help A.S.A.P
    Regular Member gangleyshag's Avatar
    Jul 2009
    kidderminster
    Default 2 problems need help A.S.A.P
    i have nor reverse lights, have checked all the fuses none have blown, checked the mount on the gearbox, the plug part and its getting no power, we put power to it, and they still didnt come on.
    also my cruise control isnt working. the light doesent even come on the dash when i start the car.
    ive tried fuses but cant see which one it is.
    i think my only option is vauxhall but i dont want to pay top fees.
    Not sure the light is supposed to come on when you start it - CC - have you checked the brake and clutch switches are not sticking?
    Regular Member garvey's Avatar
    Co Durham
    do your reverse lights come on when turn the timer lights on when you leave the car by flicking your main beam
    Feb 2006
    Dorset
    was going to suggest the same thing ,flick the mainbeam with the ignition off the see me home lighting should come on . this puts on the headlights and reversing lights .
    Ashington, Northumberland
    You have to have the drivers door open to do that btw
    11 Post(s)
    Quote Originally Posted by gangleyshag View Post
    The info in the handbook is wrong. I've yet to see a Vectra-C CC light come on as a check light when the key is first turned.
    One of the usual culprits is a weak clutch pedal return spring. Try lifting the pedal up with your foot to see if the CC then works.
    Also, the brake pedal needs to be pressed to wake up the CC at the start of a journey. Once pressed, the CC should then work until you switch off and restart the engine.
    Ex-Staff Full Member Spelly's Avatar
    Derbyshire
    6 Post(s)
    If the Vec C is same as most other vaux then the reversing light switch is normally open to an earth. This means that when you select reverse the switch contacts are made and the switch earths. To test the switch simply unplug the connector on the switch and bridge the connection with a paperclip or something similar. This must be done with ignition on. If yours lights now come on then the switch is faulty
    H.T.H
    Jul 2009
    kidderminster
    Quote Originally Posted by Spelly View Post
    H.T.H
    linked the 2 together and still nothing at all.
    i will try the cruise control today on the way up to the mot.
    thanks all
    Regular Member si_hoss's Avatar
    Apr 2009
    Stevenage, Herts
    thanks all
    Sounds really stupid and simple, so apologies in advance, but have you checked the two reversing bulbs haven't blown? One may have gone without you noticing and now the second has you may have noticed?
    One my last car one headlight bulb popped 24hours after the other did!!! REALLY hacked me off that did lol
    Edinburgh
    sure he would have got a warning about the bulb if it had blown? maybe the reverse light switch is knackered? had to replace one on my Mk4 Astra before.
  1. z18xer vvti, problems, problems
    By gstore in forum Engine & Drivetrain
    Last Post: 20th April 2012, 13:33
  2. 1.8 vvti problems, problems problems!!!
    By gstore in forum Petrol Engine related
    Last Post: 3rd March 2012, 01:31
  3. crusie control problems, anyone had similar problems?
    By rozzer2006 in forum Engine & Drivetrain
    Last Post: 2nd October 2011, 21:20
  4. GSi problems
    By Piemyster in forum Engine & Drivetrain
    Last Post: 27th July 2011, 20:11
  5. 1.9 cdti auto problems problems
    By trigger in forum Engine & Drivetrain
    Last Post: 28th September 2009, 17:20
